586,106 active members*
3,160 visitors online*
Results 1 to 7 of 7
    Jan 2016
    15
    Bridgeport EZ Vision arc compensation
    Ok this one really has me confused! My Series 1 has an issue with milling the inner diameter of any circles. I’ve tried conversational, pocketing, profiling both conventional and climb milling and my inner diameter is always smaller than expected. My circles are perfect when milling to a certain outer diameter and other profile cuts. I’m not aware of any cutter compensations in my programming or in the machine itself. As an example if I mill a circle with .600 diameter, it ends up at .591. Any suggestions on what to look for or test?
    Dec 2013
    5717
    Re: Bridgeport EZ Vision arc compensation
    Are your pockets OK?
    If everything else is OK, then all I can think of is that the endmill is undersize by about 0.004, there is a tool offset stuck in the machine controller, or there is a non-zero ''stock to leave'' setting in the CAM setup.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2016
    15
    Thank you for the response. I was also trying to mill some .875 holes with a .250 milling bit and had to tweak the settings to say my bit diameter was .241 in order to get the proper diameter. This is NOT fun! How could the machine only have an error for inner dimensions and not outer?
    Dec 2013
    5717
    Just out of curiosity did you measure the bit? I actually have some new solid carbide 1/4 bits that run from 0.246 down to 0.239. But if I enter the actual size, they cut correct, both ID and OD. I assume that is not what is happening in your case.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2016
    15
    Jim,
    Yes I measured and the bits were fine. That would make sense if my circle cuts for OD were off too. However I’m only struggling with ID cuts.
    Dec 2013
    5717
    I figured that you had, I was just checking. The only thing left is a setting in your CAM setup. We had a similar problem on the OD of a part and finally found a ''stock to leave'' was set to non-zero for that operation. I can't imagine any setting in the machine controller that would cause this to only affect the ID of a arc. A tool offset should affect both ID and OD.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2016
    15
    Just want to provide an update. While I’m not 100% certain, I did figure out there were some settings in the Tool Table that might’ve been causing my problems. I have since cleared the table (& everything else I could find) and lately my bores have been spot on. I’m still learning every day I play with with this Bridgeport. Finally making chips and parts that actually look like my CAD!!!!
  1. finding info on bridgeport ez vision mill
    By carsonc in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2014, 07:44 PM
  2. Replies: 0
    Last Post: 06-17-2013, 05:42 PM
  3. Bridgeport/Hardinge EZ Vision Mill Wiring?
    By pjs1inc in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2010, 02:09 PM
  4. Bridgeport EZ-Vision Connection
    By Mikey1719 in forum Bridgeport / Hardinge Mills
    Last Post: 07-17-2010, 03:05 PM
  5. New Bridgeport Ez Vision mill
    By JIMMY in forum Bridgeport / Hardinge Mills
    Last Post: 03-13-2009, 12:59 AM
