586,111 active members*
3,553 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > can't get access to resolver on X axis motor
    Mar 2012
    16
    voltages test find for the x axis from the side panel. Pull the J2 bullet connector out and measured sightly over 1.7V
    I am about to remove the X axis resolver, but is seems to have a shield over the whole motor. Does this shield come off by itself or I need to take the whole motor off?
    Feb 2007
    171
    Re: can't get access to resolver on X axis motor
    Quote Originally Posted by centaur91 View Post
    If you are working on a MTR-0002 you must remove the cover bolted to the face of the motor. Remove the end from the motor and the resolver will be staring up at you.
    FadalCNC Tech Support
    Mar 2012
    16
    Quote Originally Posted by ASIGuy View Post
    thanks.
    I hope the tach is easy to reach once it is opened up.
Name:	fadal x axis.jpg
  1. z axis resolver adjustment - 2000 4020h
    By peakcnc in forum Fadal
    Last Post: 08-13-2018, 10:33 PM
  2. Z-axis resolver issue on Cincinnati Milacron Horizontal Mill
    By patty sanders in forum Cincinnati CNC
    Last Post: 01-06-2011, 03:52 PM
  3. z axis resolver
    By Delw in forum Fadal
    Last Post: 06-26-2009, 08:38 PM
  4. C-axis resolver
    By EPTech in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2009, 02:04 PM
  5. Y axis resolver/over temp faults
    By smittys800 in forum Fadal
    Last Post: 06-11-2009, 05:57 AM
