586,069 active members*
3,587 visitors online*
    Linear Bearings & Rails
    I've been searching around manufactures websites. Hiwin, THK, SKF, & Igus. There are a lot of options available.
    Which did you pick (make & model) for your build and why?
    Re: Linear Bearings & Rails
    Surplus 20mm Hiwin from Automation Overstock, because they were cheap.
    May 2005
    3920
    Well I did not have a personal build yet but can say this; at work it would be possible to find tools that use all or nearly all of those brands for various linear motion needs. It comes down to fitting the hearing tech to the application at hand. Given that I mostly see HiWin and THK. In a CNC router, using squarish profiles I really don’t think brand makes a huge difference.
    Note I said “squarish” because there are all sorts of profiles on offer for linear rail solutions. Some rails are very wide and thin leaving then little in the way of application in large routers.
    Jan 2006
    738
    Hiwin, thk or similar. After 5 machine builds this is my choice. And be sure to get the seal/wiper ends for the bearing blocks to keep the dust out of the bearings. Round rod with ball bushings, not rigid enough. Round rod or pipe with ball bearing rollers wear flats on the rods and become inaccurate.
    Best of luck
  1. HiWin Linear Rails and Bearings
    By Paul-JB in forum For Sale Only
    Last Post: 04-19-2016, 12:55 AM
  2. momus with linear rails/ linear bearings- Any one tried?
    By sa7o in forum Momus Design CNC plans
    Last Post: 07-11-2014, 08:23 AM
  3. Tons of used thk linear guide rails and bearings
    By jimmyjames1981 in forum Linear and Rotary Motion
    Last Post: 01-01-2013, 05:16 PM
  4. Linear Rails and Bearings
    By Robyn in forum News Announcements
    Last Post: 08-30-2006, 04:10 PM
  5. Linear rails and bearings- overkill?
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 01-30-2004, 10:43 AM
