586,111 active members*
3,239 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > HIT-200M how to reference turret?
    Sep 2018
    Question HIT-200M how to reference turret?
    Hello!
    I have cnc lathe Hyundai HIT-200M, it's on Sinumerik 840D.
    I have to make turret reference, it's on Mitsubishi MRJ2S-100A servodriver, turret have absolute encoder so there's battery for hold on memory of zero position.
    But battery was broken, and i have alarm at mitsubishi AL.90 which means "Home position return incomplete".
    Anyone know maybe how to make reference of turret at this machine?
    Thank you and best rewards!
    Jan 2013
    4
    Re: HIT-200M how to reference turret?
    Hi
    Did you solved the problem
    I have also these problem on the machine
    Hello!
    Jan 2013
    13
    Found this one, but not sure for which controler it is.
    Subject Turret Ref. Point in case wrong Position (HIT200-250M)
    _ Machine power (Maschine Einschalten)
    _ Move the Turret to pso 7 ( Revolver auf Position 7)
    _Power off Machine (Maschine ausschalten)
    _ disconnect Turret Mitsubishi AMPlifier cable TU,TV,TW and R13,S13,T13 and CN2(Enc) cable (nebst stehende Kabel loesen)
    _Machine power on (Maschine einschalten
    _EMG release and power on (Notaus schlater betättigen um Maschine einzuschalten)
    _ push resetbutten and at Display appear T15 ( reset schalter betättigen and am monitor wechselt T7 zu T15)
    _Alarm 700117 Turret Servo alarm appear (Alarm 700117 erscheint)
    _push EMG Button (Not eindrucken)
    _Machine power off (Maschine ausschalten)
    _ connect Turret Mitsubishi AMPlifier cable TU,TV,TW and R13,S13,T13 and CN2(Enc) cable (nebst stehende Kabel wieder Klemmen)
    _Alarm 16 at amplifier will apear, if not while booting disconnect and connect the Encoder cable CN2(ENC)!(Alarm 16 am Amlifier erscheint),
    wenn kein Alarm16 erschent, dann Encoder Kabel während bootens einstecken und wieder abnehmen.
    _Mode select Key to Ref. ( Mode schalter zu Ref.)
    _reset ( reset schalter betättigen)
    _Mill Tool orient ( Mill werkzeug orientieren)
    _Menue select, push right side arrow >, start up , password, SUNRISE nad set password
    _ PLC
    _ input M16.7 (M16.7 eingeben)
    _change (ändern
    _1 input (1 eigeben
    _ accept (übernahme)
    _ unclamp the Turret (revolver losen)
    _move the Turret manuel to pos 1 and clamp again (revolver zu position 1 manuel drehen und klemmen)
    _ Machine power off (Maschine wieder auschalten)
    _ Machine power on (Maschine wieder einchalten)
    _ EMG release (Notaus loesen)
    _ power on (Maschine einschalten)
    _ Mode selection to REF. (Mode Key zu Ref Position drehen)
    _push Single Block , Reset and Rapid Button at same time (drücke single Block,Reset und Rapid schalterzugleich)
    _Tool select to Forward (FWD) (revolver schalter zu Vorwärts)
    _push the Tool Select Button T15 will change to T1 (drücke nun den revolver schalter and T15 ändert sich zu T1.
  1. Amada Vipros 357 TURRET PUNCH losing reference
    By Florcampos in forum Uncategorised MetalWorking Machines
    Last Post: 08-29-2018, 12:30 AM
  2. Mazak QT Smart 200m Turret Height
    By stewyb in forum Uncategorised MetalWorking Machines
    Last Post: 05-31-2017, 12:57 PM
  3. Replies: 0
    Last Post: 11-20-2016, 01:54 PM
  4. error code 2018 turret reference required
    By progeny in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-24-2009, 06:43 PM
