586,043 active members*
3,669 visitors online*
IndustryArena Forum > CAM Software > MadCAM > madcam simulator
    madcam simulator
    HELLO ,
    IN MADCAM WHEN THE MACHINE MOVE FROM ARIA TO ANOTHER ARIA , THE SAFE Z SOMETIMES BE GOOD DIPPENDING ON THE THING THAT WE ARE CARVING BUT SOMETIMES IT WILL CRASH WITH THE THING THAT WE ARE CARVING AND IN THIS CASE IT WILL CUT SOME EXTRA ARIA FROM THE THING THAT WE ARE CARVING .
    IN MADCAM , IN EVERY TOOL PATH THERE SHOULD BE SETTING TO GIVE IN THE G-CODE THE A AXIS POSITION , AS SOMETIMES THE MACHINE FINISH ON A180 AND THE NEXT TOOLPATH THE TOOLPATH START FROM A0 BUT IN THE G-CODE IT IS NOT LISTED ON THE TOP A0 SO I GO INTO THE G-CODE AND I WRITE A0
    THANK YOU
    Dec 2011
    97
    Re: madcam simulator
    I realize this is pretty old, but something you can look at is the "Cut-link distance" in Tool..Speed/Settings. If this is too large, the tool path will link separate cuts without using the safe z height. You can try reducing it and see if it helps.
  1. Stock does not show up in madCAM simulator
    By ajohnblack in forum MadCAM
    Last Post: 01-30-2018, 08:37 PM
  2. Simulator
    By Olavi in forum MadCAM
    Last Post: 01-20-2014, 11:54 AM
  3. As A CNC Simulator ONLY
    By MetalShavings in forum Mach Mill
    Last Post: 10-17-2010, 12:22 AM
  4. CNC Simulator
    By rhino in forum Uncategorised CAM Discussion
    Last Post: 11-01-2006, 08:49 AM
