586,071 active members*
3,915 visitors online*
    Aug 2008
    406
    DM3000 LATHE DRIVER
    PIN 1& 2 is 48 volts,,, ,3 & 4 GND-2 ,,PIN 5 IS + 5 VOLTS,, PIN 6 IS STEP ,,PIN 7 IS DIRECTION,,,PIN 8 IS HERE ..Can someone please tell me what signal is pin 8 ? I would like to connect the drive to 48 volts and see if the motors work .I will connect the step and direction to my break out board and try driving it with Mach 3
    Apr 2006
    40
    Re: DM3000 LATHE DRIVER
    The pin here goes into the microcontroller on pin 12, has a 10k pullup resistor and currently has no function and should be kept unconnected
  1. DM3000 LATHE SPINDLE MOTOR
    By gabedrummin in forum Dyna Mechtronics
    Last Post: 01-15-2019, 12:48 AM
  2. DM3000 NC Lathe
    By bolster55 in forum Australia, New Zealand Club House
    Last Post: 07-01-2018, 03:56 AM
  3. Dyna Dynamyte DM3000 cnc lathe
    By Cliff. Johnston in forum DynaCNC
    Last Post: 05-12-2009, 02:42 PM
  4. Replies: 4
    Last Post: 03-31-2009, 07:51 PM
