How To Set Parameters In The Rack-driven Woodworking CNC Router Controlled By DSP A11 System,if you have any question?please contact me?
https://www.youtube.com/watch?v=h1L1...&index=10&t=0s
https://www.youtube.com/watch?v=pQ1T...&index=11&t=0s
E-mail: [email protected] Web: www.elephant-cnc.com
--------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
Thank you, this is very useful to me. However, I still have some questions. I sent you an email and I look forward to your reply!
Could you please post Q and A here?
(If it's not private or confidential of course!)
hello ,if you have any question ,please contact me ,our mail: [email protected]
To be first brand CNC Manufacturer & Wholesaler platform.
This is our website?there are a lot of instructional videos on it, if you are interested, please look at it.
https://www.china-cnczone.com/catego...ol-system/dsp/
How To Upgrade DSP A11 Control System
How To Work In DSP A11 Handle Control System
Display The Function Of High/Low Speed Mode In DSP A11 Control System
Do you have a setup guide for setting spindle speed control?
Are you a DSP A11 system, if so, please see:
Attachment 414014
On/off button and z+ button are increasing speed
On/off button and z-button are speed reduction
Thanks for the reply. What you are showing in the picture is how to control spindle speed manually from the hand control.
This works in two ways:
1. When the machine is not running G-Code:
1a. Holding the two-button sequence of "On-Off" and the "Z+" or "Z-" button to increase or decrease spindle speed
2. When the machine is running G-Code:
2a. Pressing the "Z+" or "Z-" button to increase or decrease spindle speed dynamically
What I am asking is how to set up the A11 so that it responds to the spindle speed using the "S rpm_value" word embedded within a G-Code program.
No way.
A11 has dedicated digital outputs that interfaces with VFD in which are programmed different speeds that correspond to A11 outputs.
No PWM or 0-10V output from A11 (or any of that kind of CNC controllers with Ti DSP inside, made by Richnc - or knockoffs).
Make no mistake between my personality and my attitude.
My personality is who I am. My attitude depends on who you are.
Yes, understand the A11 controls spindle speed using a set of binary numbers. (1-8)
Example spindle speeds:
6000
9000
12000
16000
20000
22000
24000
(or similar depending on the spindle/drive combination)
The above corresponds to the spindle speed steps obtained via the DSP speed numbers 1 through 8. I have my A11 selecting the nearest RPM corresponding to the speed value (1-8) according to the above but am wondering if there is a better way to do it.
Example, If I select S1 spindle stays stopped. S2000 or S5000 would select 6000 RPM (closest to 6000 and slowest RPM I have), S8000 or S10000 would be 9000 RPM, S16000 is 16000 RPM etc.
The A11 shows the selected speed using the values 1-8.
Ask Richnc to rewrite the code for dsp
As I wrote, there is no other way to select spindle speed.
Hello, friend, you can refer to this video
https://vk.com/elephantcnc?z=video40...wall_409164950
How To Use Tool Sensor In DSP A11 Handle Control System
How To Input File In DSP A11 Handle Control System
How To Back To "Home" In DSP A11 Handle Control System
How To Continue To Work After Set The Breakpoint In DSP A11 Handle Control System
Display The Function Of Step Mode And Distance Mode In DSP A11 Contol System
