586,047 active members*
3,784 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > How to cut Ali side plates for a new CNC ROuter
Results 1 to 9 of 9
    Jan 2007
    626
    After owning a chinese 6040 for a few years, I am contemplating building new, bigger, stronger CNC Router using Extrusion.
    I want to use Ali 20mm side plates for the gantry, but how do I cut them, cheaply?
    I had a silly idea( Do you think this would work?)......Build the new machine out of Extrusion design the plates in CAD. and use the 6040 to cut out all the plates in MDF.
    Asemble and use ththe NEW machine to cut all the final Ali plates? ( Is this as silly as it sounds?...lol)
    Anyone done this?
    Other options?
    I don't think I could cut 20 mm ALi plates on my 6040. This is the whole reason for building a new machine.
    Only other option is to design and test fit the plates out of MDF and try to find someone to pay to cut them all out?
    Re: How to cut Ali side plates for a new CNC ROuter
    Sure you can. You a single flute "O" flute bit, ans make very shallow passes, 0.25-0.5mm deep.
    ericks Guest
    I agree with Gerry...use your 6040, i am using mine for my build. Cutting 25 mm thick plate, not perfect but acceptable
    Jan 2007
    626
    Ok....Maybe I sould have said that I didnt think i would live long enough to get it done on the 6040....lol
    So the 'MDF' or maybe '19mm ply' thing is a silly idea?
    Sent from my SM-G920I using Tapatalk
    ericks Guest
    Yes it sure will take a beating doing all that aluminium milling
    Mar 2018
    70
    Hi. If you just want to cut the plates you can use a miter saw. Today I used this one for 20mm plates. With much WD40 coolant and multiple slides it works very good, even with the original HM blade the saw comes with.
    https://www.amazon.de/s?k=TC-SM+2131...ref=nb_sb_noss
    Jan 2007
    626
    Quote Originally Posted by millhouse_ View Post
    Thanks Millhouse. I was also concerned about drilling all the holes in the correct places, but I guess that would be an option. thanks again.
    Mar 2018
    70
    It is possible to drill very fast if you use extra short drills (they are accurate even if abused) and a strong 2-speed drill within a solid drill stand like wabeco offers.
    PS: Everything (more parts lying around here..) done with a drill stand and a slide miter saw...
    The part that took longest was marking all the holes with a height gauge... All the damn holes.
    Jan 2007
    626
    Wow...looks good.
    Im a way off trying that yet. Got other things I have to do....lol
  1. Laser cutter for Aluminum plates and Acrylic plates in one machine
    By Yordanu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-29-2015, 12:20 PM
  2. Openbuilds OX CNC Router Aluminium Gantry Plates
    By ASB79 in forum For Sale Only
    Last Post: 04-04-2014, 07:57 AM
  3. (2) Aluminum Plates needed for CNC router
    By BWay in forum Employment Opportunity
    Last Post: 10-22-2010, 03:09 PM
  4. Aluminum Side Plates
    By csdisme in forum Employment Opportunity
    Last Post: 11-18-2009, 06:24 AM
  5. Single Side driven Router?
    By keyne in forum DIY CNC Router Table Machines
    Last Post: 03-26-2006, 04:31 PM
