586,051 active members*
3,712 visitors online*
    Need simple discs cut from 6061 aluminum
    I need these all the time and would send similar jobs your way often if you’re interested! I can have metal sent to you if needed.
    Discs from 6061 T6 aluminum. 4mm (.16”) thick.
    1.) 38mm (1.5”) diameter (quantity 200... listed quantities would be my preference, but can do more or less if easier for you.)
    2.) 31.75mm (1.25”) diameter (quantity 250)
    3.) 25.4mm (1”) diameter (quantity 150)
    4.) 21.59mm (.85”) diameter (quantity 150)
    condition of edges is unimportant. I would also be interested in discussing adding a single hole to them. Please leave email address where I can contact you if you are interested in working with me. Thank you!
    May 2003
    323
    Re: Need simple discs cut from 6061 aluminum
    Pm me
    Your pm is disabled
    Sent from my MHA-L29 using Tapatalk
    Oct 2010
    156
    I can offer you a quote. Please send me a PM.
    Sep 2006
    1738
    Leaving email.
    Shoot me over some more information:
    [email protected]
    Regards,
    Jason
    Thanks I found someone!
  1. 2" x ..063 aluminum discs
    By popspipes in forum Tormach Personal CNC Mill
    Last Post: 12-12-2014, 03:13 PM
  2. Simple 6061 Machining RFQ
    By Hellbringer in forum North America RFQ's
    Last Post: 11-02-2013, 03:10 AM
  3. 4 150x35 6061 discs, and 2 200x38x75mm mirrored steel parts
    By cgwiita in forum Employment Opportunity
    Last Post: 10-29-2010, 09:04 PM
  4. RFQ 6061 T6 simple 2 axis parts.
    By nate in forum Employment Opportunity
    Last Post: 08-13-2010, 12:58 PM
  5. Simple 1/4" thick 6061 plate
    By Aaron92SE in forum Employment Opportunity
    Last Post: 05-16-2008, 10:47 PM
