586,061 active members*
4,414 visitors online*
Thread: Cpu5a damage
    Cpu5a damage
    Sir my 2 board of eding cnc hasbeen damaged 1 is cpu5a only 2 led lights on board turned on 1 and 2 red continuously on and the other is 6 axes cup which is burned out due to sky electricity can you repair it for us?
    Re: Cpu5a damage
    You should contact Eding directly.
    Mar 2007
    2083
    Re: Cpu5a damage
    I agree with ger21 contact Eding first for repair
    I would check the power supply is working correctly
    and disconnect as much as possible to to test the cpu5a or 6 axis board on its own
    to prove its the Eding board thats faulty and nothing connected to it
    looking at the cpu5a_flyer_tech pdf
    cpu5a_flyer_tech.pdf
    it looks like Eding have used a PIC Chip from https://www.microchip.com/
    I expect with the USB connection directly going to the PIC
    the lightning strike will of damaged the PIC chip and Eding will be the only ones able to program a replacement
    manufactures are usually very protective about the firmware and don't release it to any one
    for reliability it may be better to replace the boards
    even if the faulty parts can be replaced others can fail within a few months to a year
    John
    PS
    it could be worth asking if they will sell replacement boards at a discount in exchange for the old board
    ( I know from my day job that broadcast equipment manufactures do )
    Feb 2019
    Eding CNC here
    Yes we do have replacement boards. We also offer a discount. You don't have to pay for the software again, since you have already paid for the licence. You only need to send it back, else everybody will claim that their board is damaged ...
    Regards,
    Alfred
    Eding CNC
  1. What Damage Might I Have Caused?
    By Overtorque in forum Knee Vertical Mills
    Last Post: 05-18-2018, 03:05 PM
  2. Part Damage
    By platonas1 in forum Mastercam
    Last Post: 09-24-2016, 05:46 PM
  3. Replies: 1
    Last Post: 03-22-2016, 08:39 PM
  4. what did I damage?
    By MAS in forum Stepper Motors / Drives
    Last Post: 03-20-2011, 06:18 AM
  5. H2O Damage!
    By Klox in forum Waterjet General Topics
    Last Post: 06-03-2004, 07:45 AM
