Retrofitting a plasma table which previously had a Num720 controller as well Baumuller D/C motors. Have purchased Camsoft Lite & Galil 1822 motion control. Found Baumuller drives drift without I/P to the Nsoll +/- (equivalent to command I/P) although with adjustment to drift they seem to become somewhat steady. When connected to ICM2900 motor moves & voltage read from MOCMDX to GND = approximately 2.2va/c or .2v +/-.1 d/c.
I have decided to purchase drives possible from Automation Direct (SureServos). I am curious to know if there have been any problems with using these drives & motors with Galil & Camsoft or would this be the right way to go.
By the way, not sure what will happen with these Baumuller drives & motors as well the num controller, someone out there may be able to make use of them?
Thanks in advance,
Bap
