My apologies for a long first post. If this is the wrong forum, please feel free to relocate.
I’m planning on getting a CNC router later this year primarily for hobby and maybe eventually small luthier commercial production (my son, not me). My interests are working in wood (carvings, boxes, decorative items, maybe furniture and the occasional bit of cabinetry) and, down the road to support my car hobby, aluminum up to maybe 0.5” for one-off brackets, interior trim pieces and the like, and maybe some plasma sheet metal cutting. I might want to play with a 4th axis someday, but that’s not an immediate need/interest. I’m completely new to CNC so not invested in any particular family of controller or controller software. However, I’m not new to building mechanical things, assembling electronic equipment or wiring. I’ve always purchased the best tool I could afford, and I’ve read the “buy your second CNC first” advice. Finally, I’d like to keep the overall budget for this purchase to $12,000 or so.
I’ve been doing my usual OCD on-line research and have tentatively concluded that a CNCRP Pro6060 (think Baltic birch) set up for NEMA 34 motors, with an extended gantry and a leg kit would be my best bet for the mechanical basis of my machine. While I’d prefer a welded steel frame machine, nothing in the DIY sphere seems to offer a better foundation at this size than the CNCRP machines. I’m a little concerned about the overall weight/stiffness of the bolted assembly, but despite looking online for vibration/stiffness issues with the CNCRP machines, I’ve come up empty. Nonetheless, I’d plan to add sheer to the legs, and maybe a shelf for storage/weight. So, tentatively, CNCRP for the basic mechanicals, at about $6,200 for the Pro6060 with extended gantry and leg kit.
As much as I would love to be able to go with the CNCRP PnP electronics, I’m not impressed with what I’ve read about Mach3/4, and that seems to be the lane CNCRP wants to stay in. I’m also not interested in paying for a PnP controller that I would have to adapt to use another system, which would no longer be either PnP or supported by CNCRP. So that leaves me building a controller, assembling the other electronics and relying on the kindness of strangers for tech support.
I’ve read with interest the reviews of the Centroid Acorn, and am particularly intrigued by both their long history in CNC and their apparent interest in supporting the DIY CNC router community, including apparently offering a router version of their CNC12 Pro software in the near future. If I ever went to a 4th axis in the future, I could run the slave for the Pro6060 off the basic Y axis, so I think I would be good on capacity.
I’m thinking DMM Dyn4 drivers, motors, cables, etc. I figure I should be able to do all of the electronics (enclosure, contactors, breakers, filters, controller, motors, cables, and the rest of the stuff I’m trying to get up to speed on) for about $3,000-$3,200.
I plan on getting a Chinese spindle, but don’t have any good idea what or from whom yet. I’m tentatively budgeting $500 for a 2.2KW spindle and VFD.
For software, beyond Centroid’s CNC12 Pro (hopefully for routers), I plan on VCarve Pro and Fusion 360 (both of which I’ve looked at but would need to learn as I went). I like the idea of the parametric design in Fusion 360.
With tooling and the inevitable “oops, forgot that” items, I think I’m right around (or maybe a bit over) my $12K. That’s not a hard number, but more a self-imposed desirable limit.
For me, the process of assembling the table, mechanicals and controller would be nearly as much hobby/enjoyment as the eventual use of the machine and I like the idea of knowing as much as possible about my equipment.
Questions:
1. Are there options other than the Pro6060 I should look at for the mechanical basics?
2. Would a Pro4848 be materially more solid than the Pro6060?
3. Are there options other than the Centroid Acorn I should look at for the basic CNC controller?
4. Are Dyn4’s over kill for a Pro6060? Is the machine stiff enough to take advantage of their capabilities?
5. Any specific recommendations on spindle size/cooling/source? Is my $500 estimate in the ball park?
6. Does this sound like a reasonable plan?
7. Is there something I haven’t thought of that’s going to blow my budget?
8. And the biggest question of all, would I be better off kicking my budget to $15-16K and getting a CAMaster Stinger II (ready to go (theoretically), seemingly good customer and tech support, but steppers vs. servos, smaller work area, maybe a smaller user/peer-to-peer support base)? In other words, what are the pros and cons of what I'm proposing versus a Stinger II?
Thanks in advance for your thoughts/advice/recommendations. I know how much fun it is to spend someone else’s money.
