586,033 active members*
3,532 visitors online*
IndustryArena Forum > MetalWorking Machines > Auto Tool Changer > OKK PCV-40, M86 Control, ATC Error
    When I try to do a ATC cycle the arm will come down and swing to grab the tool, but the spindle is not releasing the tool. If I manually push the tool release button on the front of the spindle, I can change tools by handle just fine.
    Re: OKK PCV-40, M86 Control, ATC Error
    Quote Originally Posted by mstoecklin51 View Post
    Found the problem, the atc motor was out of phase and running backward
  1. Replies: 2
    Last Post: 03-10-2017, 08:21 PM
  2. T-2 control, Error code 533
    By iperel in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-04-2014, 10:38 PM
  3. GE control error message
    By Good_GuyMN in forum DNC Problems and Solutions
    Last Post: 02-14-2009, 08:22 AM
  4. BOSS Control ERROR
    By snovak240 in forum DNC Problems and Solutions
    Last Post: 05-29-2008, 02:15 PM
  5. CNC control error
    By le_hungvn in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-06-2006, 04:55 PM
