586,071 active members*
3,931 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Biesse rover 4.35 error 1.2.10
    Feb 2019
    Hi
    I have a biesse rover b4.35 from 2004. I got this machin a boat 4 years ago and al this years I having this problem coming and going.
    It stops when the dustcap is going down ore up. Then I got the error 1.2.10 and "halt! problem in external unit" (this error text translate from Norwegian).
    I tried some things but don't help so now I need ask for help.
    Jan
    Apr 2019
    13
    Hi Jan,
    The issue with the dust hood is most likely the sensors on the cylinder that moves the hood up and down. It is very common for the hood to get stuck and not activate the sensors. The other error is a communication error with one of the devices on the machine. This can often be caused by bad connections on the modules, faulty cables, or un-grounded extraction hoses on the machine creating a static charge.
    Quote Originally Posted by JB61 View Post
    Hi
    Jan
  1. biesse rover b 4.40 ftk plc 432 error ybn.1.2.6.
    By cutewinuscream in forum Controller & Computer Solutions
    Last Post: 09-04-2019, 07:27 AM
  2. Biesse Rover A3 - PLC error
    By v3rbatim99 in forum CNC Machining Centers
    Last Post: 07-25-2019, 07:24 AM
  3. Biesse Rover 20 error ECN-26
    By Rover20c in forum DNC Problems and Solutions
    Last Post: 04-16-2019, 10:01 AM
  4. Biesse Rover B wrt error
    By tomkellner in forum DeskCNC Controller Board
    Last Post: 04-16-2019, 09:43 AM
