586,598 active members*
3,528 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Holding plastic to vacuum table
Results 1 to 9 of 9
    Mar 2018
    6
    I was wondering if anyone had any secrets or input into being able to hold PETG or Lexan sheets to a CNC router table. I am running a KOMO MACH II router with a very good vacuum pump and have no issues at all holding MDF and other woods but I am having a real hard time holding plastics to the table. They lift off of the table with hardly any effort and move around when being machined. Any input would be appreciated.
    Thx
    Feb 2019
    11
    Re: Holding plastic to vacuum table
    Which vacuum pods are you using? Have you checked their sealings?
    Dec 2003
    1230
    Are you using a pod and rail machine or a spoilboard?If its a spoilboard,I would suggest a facing cut and then lay a piece of plastic film on the areas which are exposed after locating your workpiece.You can't do much more than that.
    Mar 2018
    6
    I'm using a MDF spoil board and have fly cut both sides of it. Also blocked off all other portions of the table that are open beyond my 4'x8' sheet of PETG. This is only related to the plastic materials like PETG, Lexan and Plexi Glass. There is a huge difference when trying to hold these materials compared to MDF or other substrates...….
    Jun 2018
    362
    You could try some single sheets of newspaper (or similar) between the spoil board and work piece (similar to the plastic film mentioned).
    Mar 2018
    6
    were are you suggesting to put the newspaper?
    Jun 2018
    362
    Quote Originally Posted by marko63 View Post
    Top down according to your post:
    Top layer = Workpiece
    Paper (and plastic film on exposed areas as suggested if needed)
    Spoilboard of MDF machined/surfaced (through which vacuum is passing (presumed by previous post). I didn't ask if the edges are sealed because you implied you have been using this successfully.
    Vacuum Source sucking the above towards pump :-)
    Does that make sense?
    Mar 2018
    6
    OK I got it. Let me give this a shot. thank you for your help.
    Dec 2003
    1230
    I couldn't find a value for the coefficient of friction of MDF on MDF,but I would bet it is a lot higher that the values for just about any plastic.That still wouldn't explain why you are able to peel the plastic off the table.I would be tempted to have a close look at the vacuum system to see if it is operating at peak efficiency.For example-have you ever machined a groove in the spoilboard?If so some dust might have got into the system and there may be a filter that is a bit obstructed.Have you got any joints in the plumbing to the pump that have worked loose?The situation is puzzling as plastic normally seals really well.
  1. Torq Cut Plastic Tool Holding Fingers
    By thompson_chop in forum Bridgeport / Hardinge Mills
    Last Post: 07-07-2015, 04:58 PM
  2. Vacuum table for holding cardboard
    By rnm85 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 11-05-2012, 08:59 PM
  3. Vacuum holding workpieces
    By ihavenofish in forum Musical Instrument Design and Construction
    Last Post: 12-28-2009, 09:28 PM
  4. Holding plastic sheets
    By obsadene in forum Engraving Machines
    Last Post: 07-21-2008, 07:09 AM
  5. Vacuum Holding Table
    By Woodie1 in forum DIY CNC Router Table Machines
    Last Post: 02-08-2004, 01:40 PM
