586,096 active members*
3,208 visitors online*
Page 3 of 3 123
Results 41 to 45 of 45
  1. #41
    Feb 2019
    91
    Re: First Cnc Build With extrusion
    yeah now just need to fix the spindle holder plate because its too low
  2. #42
    Mar 2018
    70
    What size are your energy chains?
  3. #43
    1.JMC SERVO 20BIT 400Watt
    Power: 400W
    Speed: (Rated/Max) 3000/5000rpm
    Price : 190 USD EACH WITH THE DRIVER
    Do you have an online source for these servos, at that price?
    Are these the same?
    https://www.ebay.com/itm/263257465942
  4. #44
    Feb 2019
    91
    Are these the same?
    yes that right the difference is i use 20 bit incremental not 20 absolute they have 2 version maybe you should ask them for incremental since i got it that cheap you can contact jmc directly same as mine they can delivery via fedex
  5. #45
    Feb 2019
    91
    my first cut test still playing with speed cutting cast acrylic 12mm axial 3mm radial 50 ipm
Page 3 of 3 123
  1. 4x9 CNC Wood/Steel/Extrusion build
    By javabugz in forum CNC Wood Router Project Log
    Last Post: 01-19-2021, 03:14 AM
  2. Aluminium-/Extrusion CNC Build
    By millhouse_ in forum DIY CNC Router Table Machines
    Last Post: 11-08-2018, 07:54 PM
  3. 80/20 extrusion router build
    By jfong in forum CNC Wood Router Project Log
    Last Post: 09-12-2018, 05:10 PM
  4. 1st build, Aluminium extrusion based
    By andtfoot in forum CNC Wood Router Project Log
    Last Post: 11-20-2015, 03:46 PM
  5. What extrusion should I use to build a cnc table?
    By EKFER in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 05-16-2012, 04:55 PM
