586,069 active members*
3,425 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Morbidelli Z interpolation with R !!! H E L P !!!
    Feb 2019
    7
    Hello,
    I habe MORBIDELLI AUTHOR 600KL and i have one problem with
    programming.
    I am trying to make program with ALPHACAM
    to make toolpath in one 3d surface.
    I need make one mold.
    I need go in Z interpolation with deep for ex. 10mm
    On other machine i fix this problem with G CODE G17 G18 G19
    to set other work plane and program go:
    Ex G2 X34 Z-24 R30
    How i can do this on morbidelli Author 600KL
    I am programming with Alphacam if somebody have posto por this machine
    [email protected]
    Question: how to make program for Z interpolation in R????
    Dec 2008
    3109
    Quote Originally Posted by jasmin_morbidelli View Post
    Hello,
    programming.
    Ex G2 X34 Z-24 R30
    [email protected]
    You are not entirely clear...
    arc in XY ... use G17
    arc in XZ ... use G18
    arc in YZ ... use G19
    the other axis controls the endpoint depth
    Not sure on your control... but generally---
    if radius sweep is less than or equal to 180 deg. R is +ive....but if greater than 180 AND less than 360 R is -ive
    some controls when doing a full circle require IJK code instead of R
    I have worked a control that when ramping a full circle using R- .... it ended up stepping down to depth without doing any arc move, so had to change program to break circles into 2 arcs.
    Feb 2019
    7
    Re: Morbidelli Z interpolation with R !!! H E L P !!!
    Thanks for answer,
    are you ever work on Morbidelli?
    Becouse there dont exist G code G17 G18 G19 only changing work face like F1 F2 F3 F4 up down left or right side of wood.
    But if i change plane that show error like "THIS TOOL NOT FOR THIS PLANE" etc.
    Becouse Morbidelli have horizontal and vertical tool. I need mail spindle tool in vertical position.
    So, maybe its all about good post i dont know i use ALPHACAM and some post for Morbidelli but not my AUTHOR 600KL
    Any idea?
    Apr 2015
    327
    Thanks for answer,
    Any idea?
    for 3D surface programming is ussualy used linearized code. So it is not created from circular interpolation but from G1 code (xl2p in xilog command) by a tolerance which you set in CAM. About your issue, do not know what you programme. But for example Helix can look like this.
    XG0 X=117.658 Y=181.114 Z=-18 V=3000 S=6000 D=20 T=255 C=0 E=1
    XAR2 X=174.751 Y=82.249 r=65.918 Z=-17 G=2
    XAR2 X=60.565 Y=82.249 r=65.918 Z=-16 G=2
    XAR2 X=117.658 Y=181.114 r=65.918 Z=-15 G=2
    XAR2 X=174.751 Y=82.249 r=65.918 Z=-14 G=2
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
