586,108 active members*
3,113 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > What decides GPP tool command output sequence??
Results 1 to 6 of 6
    Oct 2018
    6
    Hi there,
    assume my post processor output Gcode (tool-path command) as below:
    (1)@start_of_file ==>
    (0)@vmid_info ==>
    (1)@def_tool ==>
    (1)@plane_data ==>
    (1)@absolute_mode ==>
    (1)@start_program ==>
    my question is : what decides the output sequence of these the tool-path command ?
    why @absolute_mode is output after @def_tool ?
    SOLIDCAM, the software itself sets it and I can't change ? or I can control it by setting post processor ?
    thanks for reading,
    If this issue could be find in GPPTool User Guide , please tell me , thank you!
    Mar 2017
    24
    Re: What decides GPP tool command output sequence??
    Contact your local reseller for assistance with edits to your Post Processor. They can adjust your Post to match your requests.
    Quote Originally Posted by Mark-SolidCAM View Post
    Are you saying that he shouldn’t ask solidcam doubts in here ? And contact the local reseller every time he have a doubt in solidcam ? Then what the use of this forum ?
    Mar 2017
    24
    Quote Originally Posted by antonyjose2008 View Post
    This is an open community forum for users to discuss issues and questions they have on the software but it is not an official forum. Some of us at SolidCAM come on here to help with your questions but sometimes the answers are easier to give when we connect through the official means. Here is a good example since a Post edit would require some more info and its best to discuss that directly with the Post writer. Your local reseller can facilitate that for you.
    There is no better source on SolidCAM topics then SolidCAM themselves.
    Oct 2018
    6
    Thank you for your opinion.
    Of course I can ask my reseller.
    But the question is ,they won’t teach you how to develop a postprocessor.
    They feel you don’t need them if you learned it.
    15362
    Quote Originally Posted by Wrighter View Post
    Some of these software manufactures, have to do the post processors as it is done in software they use, which you would not have access to, so if this is the case of there postprocessors there is nothing that you could learn to be able to do it yourself without the software they use
    Mactec54
  1. Tool Changer out of sequence Fanuc Oi-MC Control
    By ren3600 in forum Sharp CNC
    Last Post: 07-01-2017, 05:12 AM
  2. Physics undergrad decides to have some fun.
    By Donnelly in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-22-2011, 03:29 PM
  3. Sequence Number Before Every Tool Change
    By seattle77 in forum Post Processors for MC
    Last Post: 07-16-2009, 03:28 PM
  4. Output command for g540
    By DanOSB in forum Gecko Drives
    Last Post: 02-20-2009, 04:06 AM
  5. Are their controllers that output ASCII command(instead of pulse)?
    By JasonCampbell in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-25-2007, 11:49 AM
