586,103 active members*
3,579 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Drivers for Fanuc AC Motors
Results 1 to 2 of 2
    Hi.
    I posted in the Fanuc forum, but figured it may be more appropriate to post here..
    I am wanting to retrofit a Matsuura MC1000V with a Fanuc 3000C controller with more modern kit but am struggling with either finding appropriate drivers and driver/motor combinations.
    I have found that the X and Y motors are Getty/Fanuc AC Servo Motor 10-2000M models and the Z axis is a Getty/Fanuc AC Servo Motor 20-2000M and the spindle is a Getty/Fanuc DC Motor 5-1PM.
    I believe the 20-2000M is a 23Nm motor and the 10-2000M's are 12Nm.. I cant find any 23Nm motors or drivers that are suitable.
    If possible I'd like to keep the original motors and just run new drivers.
    I am planning on using a U300-Eth to power everything with Mach4 Industrial..
    My ultimate aim is to get the Matsuura running nicely and add an A axis.. I do a lot of vintage restorations and would be great to be able to machine the parts in house such as camshafts etc.
    Jonathan
    Dec 2003
    24221
    Re: Drivers for Fanuc AC Motors
    If they are Fanuc AC servo's, they use a proprietary means of commutation encoder that produces a pseudo sine wave.
    The do not interface with the typical AC or BLDC drives.
    There was a Zone member that came up with a convertor scheme he was offering.
    I have actually replaced the encoder with the standard BLDC encoder and ran them as BLDC for standard drives.
    Al.
    Albert E.
  1. Replies: 4
    Last Post: 03-29-2017, 01:59 AM
  2. Stepper motor&drivers,servo motors&drivers,motion control card CHINA factory
    By stepmotordriver in forum Manufacture Company Listing
    Last Post: 06-21-2014, 09:14 AM
  3. Which motors and drivers?
    By Odie9 in forum Joes CNC Model 2006
    Last Post: 02-10-2012, 03:42 AM
  4. will fanuc 20s motors work with current model drivers
    By js412000 in forum Servo Motors / Drives
    Last Post: 06-28-2009, 05:25 AM
  5. Help with motors\drivers
    By wired in forum DIY CNC Router Table Machines
    Last Post: 01-03-2005, 06:17 PM
