586,438 active members*
4,077 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > please rescue this noob :(
Results 1 to 3 of 3
Threaded View
    Mar 2019
    3
    Unhappy please rescue this noob :(
    Hi there.
    This is tankdoctor, the noob in this forum.
    Anyway, to get to the point, I have a significant problem in conversion.
    I got lasma 443 cnc machine about 1 moth ago.
    It has 3 SIEMENS AC servo motor, and TNC 410 M PLC controller to control the motion.
    After I connect the line and put the power on, It doesn't moved.
    Check the parameter and checking again, finally I got the main problem : The program in the PLC 410 M is gone.
    So, I decided to change the controller, mach 3 interface controller board.
    However, lack of the technical data(mach 3 board connection example) making my conversion procedure stop.
    So, Please.......
    Help me.
    P.S. I e-mailed SIEMENS about the pin data of motors and searched mach 3 board connection of AC servo motors.
    Attached Thumbnails Attached Thumbnails 1FT6034-1AK71-3AH1.jpg   SIMODRIVE 611.jpg   mach 3 board.jpg
