586,103 active members*
3,456 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Need help - dovetail/gib oiling
Page 2 of 3 123
Results 21 to 40 of 53
  1. #21
    Apr 2018
    88
    Re: Need help - dovetail/gib oiling
    If I remember correctly 1mm.
    Made them with a 3mm ball endmill.
    Depth is not really critical. The oil pump puts enough pressure to get the oil where it needs to go.
    But if I were to do it again I would mill the slots diagonally.
  2. #22
    Mar 2014
    1131
    Just one straight diagonal line? I mean I see some people make it Z shaped.
    I'm converting my BF20L now and everything is ready except the oil ways. The dowe tails and especially the gibs gives me a hard headache.
    Thanks.
    Sent from my MI 5s Plus using Tapatalk
  3. #23
    Apr 2018
    88
    One diagonal straight is enough. The Z shape is just for design.
    The idea with the diagonal cut is to spread the wear over the whole way width. Some say that a straight cut (like mine ) will wear a pattern on the opposing surface.
    No need to go very close to the edge. Oil pressure will anyhow push the oil out of the channels.
    And do not move the axis while the oil pump is running. The oil pressure will slightly lift the way and it will lock.
  4. #24
    Apr 2018
    88
    Quote Originally Posted by Azalin View Post
    Thanks.
    Dovetail channels can only be made straight. I used a slitting saw for this operation.
    And the gibs are drilled through where the oil is squirted.
    I have also cut a channel on the gib face. No idea if this is needed or not.
  5. #25
    Mar 2014
    1131
    I'll take what you suggest and mill a diagonal line on the ways.
  6. #26
    Mar 2014
    1131
    Just finished the x and y.
  7. #27
    Apr 2018
    88
    Looks good
  8. #28
    Mar 2014
    1131
    I wonder if I can use an involute gear cutter to cut oil channels on the dove tails?
  9. #29
    Jan 2018
    1516
    Possibly. Don't see why not. Just don't go too mad with it.
    All I did with mine was dremmel a small V shaped slot where the oil holes are. Drilled through holes in the gibs too. Seems to work ok for me.
    My holes for any kind of tube fittings were 6mm smooth ones with oiler inserts.
    I ended up popping the oilers out, drilling / tapping the holes to M8x1 and using high pressure fittings. I couldn't really find anything else suitable due to the original hole size.
    Had to put the ballscrew fittings on their own distributor in the end as well. I use flood coolant, it does get in the oil a bit from the table area. It occasionally would get through to the screw and the nuts would slightly jam up.
  10. #30
    Mar 2014
    1131
    I don't feel very comfortable to use a hand tool because I'll probably mess it while grinding the straight line on the dove.
    Do you have a link to the wheel you used with the Dremel? Was it abrasive or some kind of HSS or diamond?
  11. #31
    Jan 2018
    1516
    I used the normal abrasive type heavy duty cut off wheels for it.
    I think they're number 420.
    They're 1mm thickness.
    I may have used the 426 at some point too (1.2mm thick).
  12. #32
    Apr 2018
    88
    Any kind of cutter will do. Don’t overthink it.
    The dovetail has a 60 degree angle so the oil channel will not look that pretty. Just use any cutter you have on hand and calculate the depth of cut considering the dovetail angle and the cutter geometry.
    In case of a slitting saw the channel section will end up shaped like a triangle
  13. #33
    Apr 2018
    88
    As for fittings I used the white plastic ones from SMC with 4mm OD nylon tubing. Good quality and available in several thread styles.
    Mandatory is a good needle valve manifold. The china ones are crap. Don’t bother with them.
    And you need check-valves. Otherwise the oil from higher tubes will flow back to the lower oil ports draining the oil tubes.
    I got a set of SMC AS1201F flow control valves and I plan to make my own manifold with integrated check valves.
  14. #34
    Dec 2005
    436
    DLF: could you post some part numbers for the hardware?
  15. #35
    Apr 2018
    88
    Quote Originally Posted by cncuser1 View Post
    SMC push fittings:
    M6 thread: KQ2L04-M6A
    M5 thread: KQ2VS04-M5A
    Needle valves are AS1201F-M5-04A
    All fittings take 4mm OD tubing.
    The part numbers are for the metric version, but SMC also has imperial thread/tubing parts
  16. #36
    Mar 2014
    1131
    Hi again,
    U changed my mind and went to dremel path. It doesn't look pretty, but I think the result is acceptable.
    That bit does it's job well.
  17. #37
    Mar 2014
    1131
    This is the fitting I'll be using. M6 thread but takes 6mm tube.
  18. #38
    Mar 2014
    1131
    I drilled an extra hole to lead the oil to dove tail. But I'm not so sure if it was a good idea. What do you think?
  19. #39
    Apr 2018
    88
    Do you have tapered gibs? If so then you should be fine.
    With parallel gibs I had to make a 0.4mm metering hole on the gib side to ensure that both the gib and the dovetail received oil.
    For the other dovetail (side without gib) the metering hole was not needed
  20. #40
    Mar 2014
    1131
    Yes, the gib is tapered.
Page 2 of 3 123
  1. Oiling options for CNC
    By pippin88 in forum Benchtop Machines
    Last Post: 10-03-2013, 12:31 PM
  2. Oiling of the ways!!
    By chipsahoy in forum Fadal
    Last Post: 09-06-2007, 12:48 PM
  3. X3: Way oiling? One shot?
    By InspirationTool in forum Syil Products
    Last Post: 01-23-2007, 01:18 AM
  4. Way oiling systems
    By Greolt in forum Benchtop Machines
    Last Post: 07-26-2006, 04:39 AM
  5. Z not oiling!!!!
    By carbidecraters in forum Fadal
    Last Post: 07-07-2005, 02:26 PM
