586,114 active members*
3,279 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Need help - dovetail/gib oiling
Page 3 of 3 123
Results 41 to 53 of 53
  1. #41
    Mar 2014
    1131
    Re: Need help - dovetail/gib oiling
    Quote Originally Posted by DLF View Post
    For the other dovetail (side without gib) the metering hole was not needed
    What metering hole?
  2. #42
    Jan 2018
    1516
    Quote Originally Posted by Azalin View Post
    What metering hole?
    I'm thinking that with the 0.4mm size mentioned. He put a tiny slot across the top.
    Going from say the oil slot you already made on the carriage, to the edge of the dovetail. So the oil dripped down into the sides as well as on the top.
    If you get me.
    I just drilled a hole through my gibs in the correct position so oil would squirt straight through to the tail itself.. The other tail side already has a small hole.
  3. #43
    Mar 2014
    1131
    So a hole on the dove tail, the one without a gib is enough?
  4. #44
    Apr 2018
    88
    On my setup the oil fitting go on the side of the casting and the oil hole goes straight to the gib. A perpendicular hole was drilled so oil can get to the way surface.
    In order to achieve oil pressure at the way I had to partially block the gib channel. Hence the metering hole.
    The metering hole is just a piece of Derlin threaded to M6 and a small 0.4mm hole drilled through the center.
    I threaded the metering device passed the was hole so full pump flow reached the way and only a tiny part reached the gib.
    It was trial and error. I started with 0.8mm holes and went down until I was happy with the results.
    But, like I said. A tapered gib will retain pressure, so this is not needed.
  5. #45
    Apr 2018
    88
    You can check my Optimum MH25V thread. I posted there pictures of the oiling setup and you can see what I mean
  6. #46
    Mar 2014
    1131
    Sorry, I checked your thread but still don't know what is a metering hole.
    You mean this hole?
  7. #47
    Apr 2018
    88
    Here you go...
    See the marked area
    But as stated before, with a tapered gib machine this is not needed. The tapered gib will act as a seal and you will not loose pressure there
  8. #48
    Mar 2014
    1131
    Ok thanks.
    For the Y axis ball bearing nut I had to make my own fitting because the pneumatic ones does not fit in the room.
    Sent from my MI 5s Plus using Tapatalk
  9. #49
    Mar 2014
    1131
    Here
  10. #50
    Apr 2018
    88
    At some point I bought some very low profile compression fittings for nylon tubing. Ordered them from china (off-course)
    Worked really well and had a small form-factor. Only downside was the tubing could not be easily removed, so not really good for hard to reach places
  11. #51
    Mar 2014
    1131
    Hi again,
    I drilled trough the gib but should I also cut a channel on it?
  12. #52
    Apr 2018
    88
    Hi again,
    You have a tapered gob which acts as a seal. I would try it first without the channel and see if oil gets where it should. I am pretty sure it will
  13. #53
    Apr 2018
    88
    How’s the progress? Does it work?
Page 3 of 3 123
  1. Oiling options for CNC
    By pippin88 in forum Benchtop Machines
    Last Post: 10-03-2013, 12:31 PM
  2. Oiling of the ways!!
    By chipsahoy in forum Fadal
    Last Post: 09-06-2007, 12:48 PM
  3. X3: Way oiling? One shot?
    By InspirationTool in forum Syil Products
    Last Post: 01-23-2007, 01:18 AM
  4. Way oiling systems
    By Greolt in forum Benchtop Machines
    Last Post: 07-26-2006, 04:39 AM
  5. Z not oiling!!!!
    By carbidecraters in forum Fadal
    Last Post: 07-07-2005, 02:26 PM
