586,076 active members*
3,954 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Rounded edges on pocket finishing pass
    Trying to carve/cut a wooden cat plate and want the pocket to have rounded corners on the bottom edge. So far, I have the roughing toolpath with a 1/4" upcut bit and want to use a 5/8" (cutting diameter) core box router bit for the finishing pass. How do I make the finishing pass? I'm using fusion360.
    Thank you
    Oct 2010
    171
    Re: Rounded edges on pocket finishing pass
    andrealuc,
    So am I understanding correctly that you are looking to create a 5/16" radius on bottom edges of your pocket? (where the floor meets the walls?).
    If you created the model that way, you could simply create your 5/8" ball end mill in the tool library, then create a contour pass using that tool, and you should be good.
    There are many other ways to accomplish that cut -- however I'm guessing a bit at "exactly" what you're trying to do. Also, knowing what machine you are using may help as well.
    PM
    Mar 2013
    88
    If you rough with a flat bottom endmill, don’t forget to leave enough on the bottom for the radius at the bottom corners
    Sent from my iPhone using Tapatalk Pro
  1. Replies: 4
    Last Post: 10-28-2017, 05:25 PM
  2. Fiber laser cut steel and rounded edges
    By manakawari in forum Fiber Laser Cutting Topics
    Last Post: 03-24-2017, 06:38 AM
  3. Laser cutting a multi-pass rounded rectangle not tracking
    By rfresh737 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-11-2016, 04:46 AM
  4. pocket milling - don't want finishing pass
    By jay_dizzle in forum BobCad-Cam
    Last Post: 10-15-2010, 09:13 AM
