586,523 active members*
3,328 visitors online*
IndustryArena Forum > CAM Software > CamBam > Help needed on how to install GRBL plugin
Results 1 to 9 of 9
    Jun 2008
    91
    Guys, I have downloaded the GRBL plugin for CamBam, and am totally at a loss as to how to install it. I read something where you add the .dll files to the plugin folder in the CamBam installation, but I did that and nothing happens, it doesn't show up in the CamBam plugins dropdown. I also have no idea where I should be putting the rest of the files that came with the .dll files
    Maybe it is obvious what to do to some, but I really am clueless about it!
    Cheers
    Les
    Jun 2018
    362
    Re: Help needed on how to install GRBL plugin
    Not a CamBam user but seems simple enough according to this:
    http://www.atelier-des-fougeres.fr/C...ugin_menu.html
    1. Did you restart CamBam (might be needed to re-read the plugins folder contents)
    2. Was the downloaded file corrupt - try downloading again
    Jun 2008
    91
    Thanks - followed what looks like pretty simple instructions, but to no avail. I'm thinking of uninstalling and reinstalling CamBam and retrying but can't see how it will turn out any different
    Cheers
    Les
    Feb 2010
    155
    Are you talking about the GRBLMachine plugin?
    GRBL v1.1 Machine Control and GCODE sender Plugin
    If so, I would ask on the Cambam forum, since the creator of the plug-in is very helpful:
    Jun 2008
    91
    Ah, would I be so lucky as to be able to join it! I have applied, and despite at least 20 attempts at getting the verification e-mail plus actually sending a message to the CamBam company, I have received nothing from either. They did take my money though!
    Cheers
    Les
    Feb 2010
    155
    Sorry to hear that. The Cambam is one of the most helpful and informative forums that I have joined. I am not at my CAM machine right now, but if I remember correctly the GRBLMachine plugin creates a new tab but no entry in the Plugins menu. See the below link for a picture.
    http://www.atelier-des-fougeres.fr/C...BLmachine.html
    Nov 2008
    412
    Sorry that you have problems with CB forum. Did you register?
    If you registered your copy of CamBam the key should be emailed to you promptly,check your, trash, spam folders just to make sure..
    Good Luck.
    CamBam - Index
    Forget about global warming...Visualize using your turn signal!
    Jun 2008
    91
    Yes, I registered in the forum, but didn't receive the verification e-mail; when I click on the 'need another activation e-mail?' link, all that I get is a screen saying a new activation e-mail has been sent, but no e-mail ever arrives.
    As for the CamBam license code, that arrive with no problems a few hours after purchase, and I have tested CamBam to ensure that it is working fine. So CamBam is OK, but even after I sent CamBam a message saying that I cannot join the forum I still can't join, and more to the point I never even received a reply from them.
    I will try to contact them again, but not sure if I'll get anywhere
    Cheers
    Les
    Jun 2008
    91
    SOLVED Re: Help needed on how to install GRBL plugin
    ********EDIT********SOLVED**********
    Ok, I stumbled across the solution, more by luck than any judgement on my part - as is ever the case, I have to accept that I'l not brilliant with computer stuff.
    The answer was to download and extract TWO of the downloads to the plugins folder found on this GRBL v1.1 Machine Control and GCODE sender Plugin , I have attached a picture of the two files I used. The explanation doesn't tell you to do both, and it looks like they are different versions of the same thing
    I'd been banging my head on the table over this, and in the end it was a simple fix, so hopefully me putting it here will help prevent more bruises on foreheads!
    As ever I'd like to extend my thanks for those who chipped in to help
    (previous text) I have tried multiple times, including uninstalling CamBam completely and doing a fresh install and redownloading the plugin, but just can't get this working. Any ideas or suggestions welcomed!
    Cheers
    Les
  1. needed:mach3 plugin dll for USBMach V2
    By pallol in forum Mach Software (ArtSoft software)
    Last Post: 07-16-2022, 04:03 PM
  2. Needed older ver 4.4 of Galil-st plugin install software
    By bbutcher85710 in forum Mach Mill
    Last Post: 01-13-2019, 06:53 PM
  3. Replies: 0
    Last Post: 07-14-2016, 03:26 PM
  4. Plugin needed if using external controller or ESS
    By Docop in forum Mach Software (ArtSoft software)
    Last Post: 04-10-2016, 11:30 PM
  5. Need help to install plugin to Mach3...
    By jaru-eri in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-28-2009, 05:46 PM
