586,110 active members*
3,401 visitors online*
Results 1 to 20 of 21
    May 2009
    20
    Mach3 4th "A" Axis
    Hello to everybody! My name is Peter and I am an CNC enthusiast. I rebuilt chinese cnc machines, using only their body construction. The job that I do with those machines is milling and engraving stone slabs - like granite, marble, limestone and etc.
    A friend of mine is building different kinds of machines and he is going to build me a new cnc machine with my financial and physical help. The CNC will have forth axis - "A". So my question is:
    - Should I make the machine with mach3, because of the customization possibilities and the third party software that you can install on the windows pc, or should I choose something else.
    He told me that we can use DSP, Syntec, or Mach. He is more of a mechanic and less software guy. But he helps me a lot.
    So to make it more clear.
    What controller should I use for 4 axis cnc and should I use mach3 or maybe mach4 just for the customization that I can always make or should it be something else? Of course we are talking for cheap solutions...
    Hope that I wrote it understandable.
    Thank you all in advance!
    35538
    Re: Mach3 4th "A" Axis
    UCCNC is much cheaper, and the latest development version support G93 for rotary axis.
    It's also every bit as customizable as Mach3, and even easier.
    May 2009
    20
    Ok. A brand new and interesting thing to try and get familiar with. At first sight the UI of UCCNC looks clean and very similar to what I am use to from mach3. Thank you for the reply.
    I just need to check if UCCNC has some probing capabilities
    Jun 2015
    943
    Quote Originally Posted by peter_tash View Post
    Yes it's screen layout is cleaner than mach3's, it supports probing G31 code and it has a nice probing sceen in the latest development release.
    I attached some printscreens for you.
    May 2009
    20
    Quote Originally Posted by OlfCNC View Post
    Thank you for the printscreens. UCCNC look similar to mach3 and I am starting to like it very much.
    So here is a simple question.
    Lets say I decide to build the machine with a bit more money investment, put some nice servo, make the construction stronger. I just need to have good four axis control and probing for the uneven surfaces that I engrave.
    So. What type of controller will you guys choose in this case?
    Jun 2015
    943
    I use a UC100 on my mill and using a UC400ETH on my plasma. Now I have the AXBB-E for the 3rd (under construction...) machine.
    Jun 2018
    362
    This might be well worth a look and matches UCCNC for a nice bundle.
    forum.cncdrive.com • View topic - New ethernet motion controller+breakout board combo release
    May 2009
    20
    This looks very nice. I like it! I was just thinking, is the rotation of the spindle "head" the "A" axis or am I making some mistake?
    Jun 2015
    943
    The 4th axis is usually the A axis, because the first three are the XYZ and then ABC.
    35538
    I use a UC300ETH with a UB1 breakout board from CNC Room.
    Jun 2015
    943
    Found a video for you of Autoleveling:
    Jun 2015
    943
    And another one:
    May 2009
    20
    Great thank you! I see that autoleveler is a great tool and it is very good integrated in UCCNC. I just wonder How will I make different toolpaths that need different tools? Maybe there is some feature that can adapt second or third toolpath (with different tool) to the leveling you already made for the first toolpath.
    I just ordered AXBB-E from CNCdrive. I will try it on my 3 axis machine. I have ordered omron touch probe. Maybe next week I will have some results.
    35538
    I also don't use Mach4. After I bought my Mach4 license, I decided to switch to UCCNC.
    If you decide on Mach4, make certain that the controller you choose supports all of the functions that you need.
    Jun 2015
    943
    You can probe the tools to measure and align the tool lengths.
    You asked about the UCCNC 4th axis capability and I just found this video for you:
    35538
    The spindle spins the cutting tool.
    The rotary axis holding the part is either the A axis or B axis, depending on which way it's oriented on the machine relative to the X or Y axis.
    Mar 2019
    8
    please subscribe to my youtube channel.. i just posted on my G-code CNC PCB milling https://youtu.be/CNIyHB7awX4
  1. "Probe" and "Verify" not working - Mach3 & ESS
    By Mogal in forum SmoothStepper Motion Control
    Last Post: 03-17-2017, 07:05 PM
  2. Need help working out feed rate for "C" Axis and "Z" axis simultaneously.
    By Jonaldhinio in forum Australia, New Zealand Club House
    Last Post: 08-12-2014, 09:27 AM
  3. Replies: 3
    Last Post: 06-25-2014, 03:51 PM
  4. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  5. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
