586,655 active members*
3,609 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > machining polycarbonate with a fixed-speed router - possible?
    Jan 2018
    7
    I have my home-brew CNC setup with fixed-speed router (yes, I realize this limits me... some day i'll upgrade to a fancy water-cooled vfd spindle )
    Anyway, I want to mill some 3/8" polycarbonate. Just a basic 2D cutout, no pocketing or drilling.
    Plan is to use either a 1/8" O-flute bit, or a 1/4" 2-flute low-helix bit.
    Router runs at 27000 rpm.
    Any recommendations for doing this without melting the crap out of it? So far the only ideas I have are a lot of compressed air for cooling/chip-clearing and some WD40.
    Re: machining polycarbonate with a fixed-speed router - possible?
    You need to use a single flute "O" flute, and cut with a high feedrate. at least 100ipm, maybe even 150-200ipm.
    Jan 2018
    7
    Thanks Gerry.
    Any recommendations on depth of cut for a 1/8" o-flute?
    Jan 2018
    7
    Happy to report that i was able to get it cutout without any gumup issues or broken bits.
    Air nozzle in one hand and can of wd40 in the other. Ugly messy, but it worked.
    Only downside was some bad chatter at times. Thankfully accuracy wasn't ultra critical, as this was just a base for a vacuum shroud.
    I think I might be able to reduce that by making a wider profile path. Or maybe with a lower feed(and speed)
    Of course that will have to wait until i have a spindle capable of that.
    In any event, no plans on cutting any more of this stuff with the current setup.
  1. Replies: 6
    Last Post: 01-18-2015, 06:04 PM
  2. Hybrid Design - Fixed Gantry Router for High Speed Aluminum Milling - Metal Nibbler 5
    By Bob La Londe in forum Uncategorised MetalWorking Machines
    Last Post: 04-10-2014, 05:16 PM
  3. Super-PID speed controller installation to Fixed speed Router
    By Khalid in forum DIY CNC Router Table Machines
    Last Post: 11-13-2010, 11:29 AM
  4. Replies: 0
    Last Post: 06-11-2010, 07:59 AM
  5. Variable vs fixed speed router?
    By tryrook in forum WoodWorking Topics
    Last Post: 04-01-2009, 02:10 AM
