Hi - haven't been here for a long time...
I am building a new machine (my other one was just a test... to see if I got the idea)
-The machine I am building will require 2 steppers on either side of the Gantry... running in sync!! -this way I don't have to build a connector or have to run that connection along the bottom under the table. (an axle or a belt)
--wondering if anyone has done this or figured out how to do the electronics to sync the motors - preferably on 1 controller.
__.Yes I could just 'double up' the output from the step dir pulses to two seperate drives, but of course the problem lies in the 'lost steps' - which may arise.
-if it were propper servos then I guess I wouldn't have problem.
Some of the things I was thinking about:
A
1 controller - two motors,
-'bridge' the motors in a way that, when one loses a step, the other loses it too? -eg. whatever current spike is in one motor get's translated to the other?
B
2 controllers, two motors + encoder....
the differenec though with traditional servo system would be that the encoders would count a 'difference'between the two motors, the encoder that senses lag would 'block' the step single in that motor untill it is running intune with the other motor... electronics would be a simple comparator, blocking the step signal.
C
Same as in B, except the block would occur on the actuall drive current.
D
-Turn them into servos - yeah I could just buy some new motors.
or E --don't worry - I won't lose that many steps, and if I lose one in one motor the balancing forces in the gantry will probably soon bring the motors back into equilibrium. (hopefully centre of G is not skewed , biasing a lean in the gantry)
