586,105 active members*
3,322 visitors online*
    Feb 2019
    Wiring Limit Switch on Cronos Maker
    Hello all. I just put together a 2418 Mini CNC machine which came with a Cronos Maker controller. All works well, I have full control on X,Y,Z and spindle spins up. I have upgrade the grbl to 1.1g (latest as of 2/24/2019). But like my 3d printer, I would like to add limit switches to this unit.
    But I cannot determine how to wire up the switches. There are three 3-pin connectors labeled Z limit, Y limit and Z limit. the pins are labeled (on back of controller) S, - , and +. But if I try to close of any two pins (I am using NO switches) all I get is an alert and need to power off/on the controller to get back to normal. I cannot find any information on this controller either from Google or Bing searches. Can someone who has knowledge of this controller help me determine what the combination of pin connection to wire up.
    I have seen the controller listed as Cronos Maker and also listed under Daedalus.
    Re: Wiring Limit Switch on Cronos Maker
    Quote Originally Posted by rjh_55 View Post
    Did you ever find limit switches that worked with the board.
    I think i might have found what we want. on ebay they have these
    https://www.ebay.com/itm/6-Pack-End-....c100010.m2109
    and since our board only has 3 spots 1 for each axis, i think we need these.
    https://www.amazon.com/Phanteks-3-Pi...%2C150&sr=1-12
    Jimmy_Bondi Guest
    Hey,
    I would also like to upgrade my CNC3018 with endstops.
    Did you change any Pin Assignemt or somthing else, to grbl1.1, or can I flash it "OOTB" to my Cronos Maker controller board ?
    Oct 2015
    there are 3 pins because you can use the switches like normally opened or normally closed. NO or NC
  1. C10 BOB limit switch wiring
    By silvs in forum CNC Machine Related Electronics
    Last Post: 12-12-2017, 09:24 PM
  2. Limit Switch Wiring
    By Ron2d in forum Benchtop Machines
    Last Post: 07-17-2016, 03:59 PM
  3. Limit switch wiring
    By rstrease in forum Gecko Drives
    Last Post: 04-17-2015, 05:02 PM
  4. Limit Switch Wiring
    By The Speaker Guy in forum CNC Machine Related Electronics
    Last Post: 01-07-2007, 11:11 AM
  5. Limit & Home Switch Wiring?
    By Willyb in forum Gecko Drives
    Last Post: 10-17-2005, 10:02 PM
