586,060 active members*
4,154 visitors online*
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Dec 2009
    953
    Re: fanuc 18m 351 alarm
    so we isolate the problem that could come from the optical encoder that should be connected to spindle by a small belt?
  2. #22
    Jul 2010
    46
    I will check it tomorrow.
    Thanks for the help.
    Michael
  3. #23
    Jul 2010
    46
    I found out that the previous owner had replaced the spindle motor and this one has inside a MZ sensor although the old one had a M sensor, because the plans I have state this.
    I checked the cable of MZ sensor and the only problem I found was that the shield is not connected to earth directly, but to pin 10 of the JY2.
    I checked the parameters and as far as can judge seem ok.
    I can not understand what that would be to trigger the alarm of X-axis communication even if it seems that is something with the spindle orientation.
    Michael
  4. #24
    Dec 2009
    953
    what show diagnose 200,201,202,203,204 when alarm occur?
  5. #25
    Jul 2010
    46
    Only 2003 X crc=1 and stb=1, all others are 0.
    This morning I tried some g84 cycles and alarm 351 continuous and also #200 x dca=1
  6. #26
    Dec 2009
    953
    that means mainboard or option board fault
  7. #27
    Jul 2010
    46
    Do you know how to change the mainboard?
    I think I don't have option2.
  8. #28
    Jul 2010
    46
    Attachment 419498
    this is my mainboard.
    Couldn't reply to your PM. Your storage is full.
    Goodmorning
    Michael
  9. #29
    Jul 2010
    46
    I checked the pulse coder cable, OK.
    I added a cable to ground from the replaced MZ sensor (the machine originaly had a M sensor in the spindle motor).
    This way the alarm hasn't appeared yet.
    Let's see.....
  10. #30
    Jun 2009
    12
    hi michael .
    how to solve your problem # alm 351 ?
Page 2 of 2 12
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. Fanuc 6T-B alarm 402:servo Alarm
    By leiryll in forum Fanuc
    Last Post: 12-03-2013, 08:52 AM
  4. Replies: 0
    Last Post: 08-12-2013, 09:12 AM
  5. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
