586,441 active members*
6,509 visitors online*
    Jun 2017
    119
    Automatic THC on/off.
    Hello.
    Is there a way to make the THC go on and off when cutting holes smaller than x diameter etc?
    I've got a relay board that controls the Plasmacutter so I'm thinking the THC should be able to be turned on and off likewise?
    Thanks,
    Mr. Emo
    Mar 2017
    1314
    Re: Automatic THC on/off.
    You can turn off THC withing the g-code.
    G-code M54 P1 enables THC, M54 P0 disables it.
    Jun 2017
    119
    I'm using Proma THC SD as recommended on the website. Bought this system 1.5-2 years ago. Not sure if that would work with the SD?
    Mar 2017
    1314
    Have you tried it?
    On website we recommended the Compact THC 150 since we did not have any experiences with the SD version.
    I would suggest that you try your SD THC and see if it works ok.
  1. from automatic to manual
    By deadlykitten in forum Okuma
    Last Post: 12-21-2015, 09:08 PM
  2. automatic shutdown
    By cydrollinger in forum CNC Machine Related Electronics
    Last Post: 07-26-2011, 03:55 PM
  3. jog --> automatic by rs232
    By 0alex in forum Haas Mills
    Last Post: 02-28-2010, 08:00 PM
  4. Automatic Drawbar Help
    By Barry_ward in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2006, 12:57 PM
