586,080 active members*
3,662 visitors online*
Results 1 to 9 of 9
    Dec 2017
    7
    Cutting copper
    Hello, I would like to ask if anybody know a good way of cutting 1/4 inch copper sheet an 1/8 inch polycarbonate. I need to make a parts from it, what would be the cheapest way?
    Dec 2013
    5717
    Re: Cutting copper
    Bandsaw, hacksaw, jigsaw, tablesaw, skill saw, coping saw? I think the key word here is ''saw''
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2017
    7
    Sorry, I probably write that poorly I need to do holes in them for bolts and I would need it as automated as possible.
    Dec 2017
    7
    Quote Originally Posted by EJdm View Post
    Mostly I would need to know if I would be able to do it on some cheap CNC router from Amazon.
    Dec 2013
    5717
    Re: Cutting copper
    Yes, that would work.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2017
    7
    I have read that machinkng of copper is quite challenging, will something like this handle it? Https://www.amazon.co.uk/gp/aw/d/B07GB99WGK/ref=sspa_mw_detail_0?ie=UTF8&psc=1
    Dec 2013
    5717
    Re: Cutting copper
    Copper is a little bit tough and gummy. You won't be able to cut it like wood, but taking small bites with sharp tools will be fine. Coolant is helpful, a spray mist system would be fine. The good news is that the router frame shown is coolant friendly.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2003
    540
    Re: Cutting copper
    I've cut copper on a CNC plasma with no issues (but without the plastic backing of course). Also have use a hand router and a mill. Cuts pretty much like aluminum from my experience and no real issues. About any hand tools or power tools like a sabre saw with a metal cutting blade will work fine. If you have a scroll saw, that will also work with the right blade. Which will work best for your project depends on the size and shape of the parts you are cutting.
    Apr 2007
    100
    Re: Cutting copper
    Copper can be very bendy on flat surfaces. Also taped holes are usually undersise and so oversize taps or re-taping by hand is usually the thing to do. It is not like aluminum much IMO.
  1. Issues Cutting Copper
    By Teldin in forum Material Machining Solutions
    Last Post: 05-14-2017, 05:31 PM
  2. Cutting Copper on a Lathe.... need input.
    By MychesterCNC in forum MetalWork Discussion
    Last Post: 09-11-2011, 03:07 AM
  3. Cutting copper sheet?
    By bossfrog in forum Waterjet General Topics
    Last Post: 09-03-2011, 05:27 AM
  4. Cutting copper 2mm my first post
    By welly2000 in forum MetalWork Discussion
    Last Post: 04-08-2009, 02:32 PM
  5. Cutting Aluminum or copper?
    By Siren in forum Commercial CNC Wood Routers
    Last Post: 02-23-2007, 06:38 PM
