586,070 active members*
3,517 visitors online*
    189
    ESS not moving my axis
    Hi Everybody,
    Switching out a machine from the old parallel port to the Ethernet SS with C25 BOB. CPU is talking with the board. got the Estop to function so I know the two are communicating.
    When I power up the ESS and then boot up Mach 3 the lights on the output pins on the BOB all light up until I clear the E stop. I can see the numbers rise and fall on the DRO on the mach screen but no movement on the machine and the led's on the BOB should blink, at least the direction one. Nothing..
    Checked the pin out settings for the motor, so far I'm stumped.
    Thanks in advance!
    Is a sentance fragment?
    Re: ESS not moving my axis
    What driver is your bob connected to?
    189
    step driver? Gecko 201's
    I think you need to use a multimeter and see where you are losing the signals. Check:
    - Status of pins on diagnostics screen.
    - Status of pin on the ESS.
    - Status of pin on the terminals of the board.
    - Status of pin on the terminals of drive.
    - Status of LEDs for the pins in the breakout board.
    The step pin may be difficult to measure, but the direction pin is easy as it should change from 0 to 5vdc every time you change the commanded direction for the motor.
    If the problem continues, please feel free to open a support ticket in our website and we will give you a hand troubleshooting this:
    https://cnc4pc.com/contact/
    Arturo Duncan
    https://cnc4pc.com
  1. axis not moving Only DRO moving on mach3 screen for cnc router 6040
    By bingaom in forum Charter Oak Automation Support Forum
    Last Post: 09-09-2014, 08:54 AM
  2. Replies: 12
    Last Post: 02-07-2014, 02:40 PM
  3. Z AXIS - Moving bearings or moving rails ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 02-28-2012, 06:22 AM
  4. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  5. Z DRO moving, axis not moving
    By JC50 in forum DIY CNC Router Table Machines
    Last Post: 03-13-2011, 02:49 AM
