586,096 active members*
3,675 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > please, how to achieve oriented M axis ?
Results 1 to 6 of 6
    Jun 2015
    4154
    hello all, please, how to achieve oriented M axis, for milling and turning ? genos osp300L
    i wish to :
    Code:
        index turret + M110  + approach + index M axis at specific angle + feed movement with M axis oriented
        index turret + G97 S + approach + index M axis at specific angle + feed movement with M axis oriented
    is there a " M zero shift " ( or something similar ), so to vanish this modification when cnc is reseted, so to avoid indexing the turret with wrong M spindle phase ? kindly
    Mar 2019
    8
    please subscribe to my youtube channel.. i just posted on my G-code CNC PCB milling https://youtu.be/CNIyHB7awX4
    Jun 2015
    4154
    Re: please, how to achieve oriented M axis ?
    what g-code delivers 'orientat' for M axis ? pls check attached image
    at this position, i can't rotate the tool by hand, thus there is kind of a break; M phase is 300degrees, and when turret is indexing, M phase is changing from 300 to circa 245; i achieved the 'orientat' state by using G296, and the phase angle by editing " system para \ M orient offset ", but the break is delivered by the G296 cycle, not by pure g-code
    also, i can not insert g-code after the moment when M axis is oriented ... after G296 executes, there is the G180, and at that moment rpm is restored ?!
    Code:
    M110
    M146 M15
    G00 X30 Z2.5 T0505 SB=500
    C90
    G296 X30 Z-5 C90 K0 F0.567 E2.8 HS=-0.02 G95 (*1)
    G180 (*2)
    G00 X30 Z2.5
    M12
    M109
    G00 X500 Z200 T0500
      i wish to insert code after the moment when M axis reaches ' orientat ' state
      M axis get 'orientat' during executing line *1
      G296 cycle is canceled by G180, and when G180 is executed, rpm is restored
      i can't insert code between G296 and G180, because it will be interpreted as a new position where G296 should be repeated
    kindly
    Jun 2015
    4154
    hello past self of my self M229 CB=10; does not need M110, thus m spindle orientation is not dependant on c axis state
    May 2021
    Quote Originally Posted by deadlykitten View Post
    I LOVE YOU INTERNET STRANGER. CHEERS. I NEEDED THIS TODAY AND YOU THE ONLY SOURCE THAT HELPED. YOU HAVE NO IDEA HOW GREATFULL I AM.
    Apr 2018
    134
    :banana:
    Jun 2015
    4154
    hy sencillo love you 2, haha
    if i may, why do you needed it ? do you need something else ? kindly
    ps : hy ridersidetrack
    Jun 2015
    4154
  1. C axis oriented transfer with cutoff
    By gunda in forum Okuma
    Last Post: 02-18-2019, 09:03 AM
  2. Oriented Spindle Stop
    By vivu91 in forum Fanuc
    Last Post: 11-02-2012, 11:00 AM
  3. Oriented Thread Cutting on 18i TB
    By ecapatto in forum Fanuc
    Last Post: 08-26-2010, 04:49 PM
  4. Fanuc O-MD controller-"Magazine not oriented” message
    By machinerytech in forum DNC Problems and Solutions
    Last Post: 02-19-2009, 05:51 PM
