586,042 active members*
3,769 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Getting Ready to fire up T42-BB for first time--- Questions???
Results 1 to 6 of 6
    Feb 2019
    38
    Okay.... I'm all wound up.... in a good way!!!!
    Machine is finally moved in and electric will be finished today.
    I'm a little worried about the pull bar, I'm not positive I have all the parts.
    Looking in the collet tube, it's totally empty. I also have what I would call the collet pull tube that attaches with 8 screws. There is also a threaded ring that has a set screw on the side and holes for a spanner wrench. My biggest fear is I'm missing some parts. Am I missing anything,,, bearings,,, o-ring,,,, some impossible to find part,, or is it all there?
    The draw tube was removed when I looked at the machine under power. I had no idea it was out. I did push the buttons to open and close the collet but nothing happened. Is there a way to test the hydraulics without a collet, with or without the puller tube in place? I have two fears,,, #1 Damage the lathe,,,, #2 Push the button and watch some tube rocket out of the machine, through the concrete block wall, across the street and through the glass at the grocery storefront and impaling a clerk. LOL... sorry!!!! Thoughts???
    Thanks In Advance!!!!
    David
    Dec 2013
    5717
    Re: Getting Ready to fire up T42-BB for first time--- Questions???
    I'm pretty sure the cylinder will keep anything from shooting out the end It only has about a 1/4 inch or so of travel. Again, mine is a bit different setup, but I have cycled the closer without a collet or chuck in place.
    You might set up a high speed camera and get a video of the launch
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    38
    10----9-----8-----7
    Feb 2019
    38
    It's Alive... nothing spectacular happened. That's a good thing!!!
    Mar 2017
    411
    Very vivid imagination. Park you car between the wall and the store. That may slow the projectiles a bit.
    Sent from my SM-T813 using Tapatalk
    Dec 2013
    5717
    Quote Originally Posted by shaggyd View Post
    :cheers:
    Jim Dawson
    Sandy, Oregon, USA
  1. Couple more questions and ready to go
    By keithmcelhinney in forum Novakon
    Last Post: 03-19-2014, 12:58 PM
  2. New machine almost ready but questions?!
    By Nitrografix in forum DIY CNC Router Table Machines
    Last Post: 06-25-2013, 11:45 AM
  3. About ready for retrofit have questions
    By judleroy in forum HURCO
    Last Post: 07-07-2011, 02:50 PM
  4. SLA7051 Board - Ready for Prime time ?
    By pminmo in forum Open Source Controller Boards
    Last Post: 11-14-2005, 10:25 AM
  5. Time to wade in ready or not.
    By fair451 in forum CNC Wood Router Project Log
    Last Post: 12-17-2004, 05:14 PM
