586,114 active members*
3,279 visitors online*
Thread: Barfeeder
    Sep 2011
    104
    Barfeeder
    Hi all
    I know this might not be the right place for this question but I know there are quite competent people in the Okuma section.
    I'd like to ask you if you from your experience know how does a profiled bar change happen?
    Should the barfeeder be of a special type and how is it introduced into the barfeeder collet and the lathe collet?
    Cheers
    Feb 2011
    353
    Re: Barfeeder
    some of the answers depend upon the make and model of the bar feed
    lns332 bar feed
    you would turn the end of the bar for the pusher collet
    the bar should be well chamfered on the other end to make it go easier into the collet
    you would have round guides to support the bar
    then the bar change cycle would bring the bar to just behind the collet
    this is where the bar feed would start peck inserting the bar to get it to go into the collet (collet is running a low rpm here)
    after so many unsuccessful attempts it would alarm out
    Jun 2015
    4154
    Re: Barfeeder
    hi gunda, there are several methods :
    1) like rcs60 said, stock is chamfered at both ends, and a little bit turned od at the end that goes inside the collet
    feeder will keep on pecking, while the collet will be spinning at a low rpm
    remnant is pulled back and dumped inside the feeder
    2) some models do not have a collet, but a pusher
    there is a mechanism that rotates the bars, and gently puts them inside the v-shaped loading channel ( bars have to be oriented before the mechanism that rotates them )
    cnc spindle stops at a specific phase, and waits for the pusher to bring the material
    remnant is dumped inside the cnc lathe
    this method has the advantage that it does not require to turn + chamfer the material, but only to debur it
    3) more complex models :
    ... do not require that the material is oriented before the mechanism that puts the bar inside the v-loading channel
    ... may have sensors that detect if the stock is seating ok inside the v-channel, because, sometimes, it may not fall ok, but remain suspended at a higher position; from this moment, 2 things may happen :
    ...... when the pusher pushes the stock, it will fall, so is like nothing happened
    ...... if it does not fall, then it won't be able to pass through the reduction sleeves, and the feeder may be stopped automatically by a torque-limit on the servo
    all these should work for :
    ... round bars ( sections has many simetry axis )
    ... hex ( section has 6 simetry axis )
    ... square ( section has 4 simetry axis )
    i don't know how are handled those with 1 or less simetry axis, thus i don't know about custom profiles / kindly
    Sep 2011
    104
    Re: Barfeeder
    Good points rcs60 and deadlykitten. Thanks for the advice, I'll give it a shot and see what happens but surely will get some result that works. Cheers
  1. NLX2500/700 and barfeeder
    By Azmodi in forum Mori Seiki lathes
    Last Post: 12-03-2018, 02:35 PM
  2. Cav Barfeeder Problem
    By cncswiss in forum CNC Swiss Screw Machines
    Last Post: 11-27-2017, 03:14 AM
  3. unplug barfeeder
    By godtar in forum Fanuc
    Last Post: 01-29-2016, 06:57 AM
  4. 300 barfeeder problem
    By metaltec in forum Haas Lathes
    Last Post: 11-06-2007, 10:27 PM
  5. lipe barfeeder
    By wdzhere in forum Fanuc
    Last Post: 09-06-2006, 01:19 AM
