586,403 active members*
2,747 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Editing of PostProc
    Mar 2019
    Editing of PostProc
    Hello there
    Question about editing the post in edgecam as follows:
    Is there any lists out there of functions that you can use to pull specific settings from the program onto the nc output.
    Examble.
    I want my stock dimensions to show in my NC-code
    (* Prog. Navn : PPCMEK20124S1 )
    (* Part Navn : MEK20124SIDE1 )
    (* Maskine : MA 400HA )
    (* Lavet af : MBW )
    (* Postet d. : 03/07/19 - Klokken. 13:02:08 )
    (* Total bearbejdningstid : 7.304 Minuter *)
    ( STOCK DIMENSIONS HERE)
    Anyway this is possible?
    Regards
    Marc W
    Oct 2003
    127
    Re: Editing of PostProc
    you should be able to use the job manager tokens from the machine parameters/job data
    tokens are JM-*** ..... COM for the comment box
    Jun 2019
    5
    Hello Marc,
    If you want to see the stock dim, then input this token
    https://www.screencast.com/t/1Y24o76ZQ
    Jacob
    Quote Originally Posted by MarcW View Post
    Hello there
    Examble.
    (* Lavet af : MBW )
    Regards
    Marc W
  1. Replies: 0
    Last Post: 02-22-2019, 05:31 PM
  2. disable tool change gcode in postproc
    By cryptopsy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-14-2018, 07:09 PM
  3. Haas TL1 Mastercam x2 postproc
    By kiwigips in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-18-2008, 07:11 PM
  4. Postproc for heidenhain 4110 or 4290
    By nips in forum Post Processors for MC
    Last Post: 09-04-2007, 07:25 AM
  5. Making a Edgecam postproc.
    By stefanbaarstroe in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-16-2006, 01:47 PM
