586,043 active members*
3,736 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Indicator Resolution for Backlash Measurement
    Feb 2013
    89
    I know people may say to “use the search feature” but I had a quick question. I’m trying to complete the setup for my VMC 40 and was wondering what resolution DTI you guys used to set your machines up. I bought a .0005” Mitutoyo indicator however, I don’t know why it just occurred to me the backlash settings for the machine is in tenths so it may be more accurate to use a .0001” indicator over the .0005” one. Thanks
    Apr 2014
    345
    Re: Indicator Resolution for Backlash Measurement
    Depends how accurate you want to be. Personally I have used both you can read between the lines on a .0005” indicator.
    In my experience all my backlash numbers are under .0006” so a tenths indicator will probably be helpful but if all you got is a .0005” go ahead and use it.
    Feb 2013
    89
    Quote Originally Posted by ianagos View Post
    Hey Ianagos
    Well I'm a bit of a perfectionist so I would rather have the tenths indicator for accuracy's sake. I don't want to guess if the hand is at .0002" or .0004". I guess the silver lining is the tenths indicator will also help measure for spindle runout and other super precise measurements as well.
    Apr 2014
    345
    Yes I bought a .002mm indicator for all my really precision things. But I use a .0005 for most everyday tasks.
  1. A measurement of backlash
    By dlaery in forum Taig Mills / Lathes
    Last Post: 04-19-2012, 12:33 AM
  2. LED indicator
    By neric in forum CNC Machine Related Electronics
    Last Post: 11-17-2011, 11:59 AM
  3. Spiral anti-backlash couplers introducing backlash!
    By MArruda in forum DIY CNC Router Table Machines
    Last Post: 06-07-2011, 08:31 AM
  4. Replies: 8
    Last Post: 03-10-2008, 09:35 PM
  5. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 08:35 PM
