Re: LU300 Tool Offset Page
I have some kind of API application on my computer
hi, i also noticed that okuma api can be installed on a pc, but i don't know how relevant is this stuff ... thus i am not sure if is possible to create api applications on a pc that is not running also osp
Installation did not work
be sure that you have ' okuma api ' on the cnc, and , after that, try to contact the guys that developed that application
Please go ahead and share the details
tool corections is a set of items [ offset. wear. radius, comp quadrant ], and each item has assigned a system variable
even if you input corections through the panel, those corrections are passed to the controller via the system variables, so you may 'operate your cnc' at the system variable level
such operations can be divided in many ways, but, as for your interest, they are like this :
... relative : thus normal tool offset corections, when you add, for example 0.05 ( just saying )
... absolute : when you measure a tool the 1st time
in other words, all "relative corections" require that "absolute corections" have allready been implemented
i can help you with both of them, but 1st we should begin with the "absolut corections", so, may i ask : consider that your cnc is ok, there is no problem, and you open the doors, so to have acces inside the cabinet, and, after that, power is turned off : in this conditions, can you determine, with ±0.2mm tolerance, the origin for Z axis (program zero), and the X&Z offset for each tool on the turret ?
if answer is no, then is a good moment to calibrate your machine, so to speed up this process of initializing the offset for new tools, especially now, when you are in a "kind of blind" situation
after that, we will move to custom software & g-code soubroutines, that will manage the "relative corections" / kindly
