586,043 active members*
3,719 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463 > X2 general dimensions and some info needed
    Jan 2019
    10
    Hi guys,
    I'm mostly doing some minor stuff and repairs on mini lathe during regular wat hmaking (hobby).
    Milling on lathe attachment is pretty painful and I m considering to buy some milling vertical setup. Hence, hard to find proper one, so I'm thinking of making my own.
    Gave some rough ideo, some parts laying around etc...
    I need some info like:
    General dimensions of X2 like machines: height of column, distance between spindle axis and column, distance and travel from spindle to bench... It would be nice to know thickness of column wall, so I can look for proper material...
    Also, considering to use 2x ballscrew on AXIS so I can easily retrofit CNC later? Something like 1605 or 1204? Or I really need acme screw for manual feed?
    Finally, would hiwin hgr15 rails would be enough for z axis? Or bigger? I would avoid vee slots if possible.
    For spindle, I would use er25 shank, in cast iron body (already have properly machined body) with angular contact bearings. Motor, would try to use 550w sewing machine BLDC.
    Pulley setup, probably with XLT type, not sure yet...
    Any input, thoughts, highly appreciated!
    Sent from my LG-D855 using Tapatalk
    Jul 2018
    58
    Re: X2 general dimensions and some info needed
    there is a company converting these machines you should check them out axyzmachines.com i hope thats helpful
  1. Info on the General CNC Machines
    By Hype in forum Canadian Club House
    Last Post: 11-18-2010, 03:06 AM
  2. general info
    By metalmach in forum MetalWork Discussion
    Last Post: 10-20-2009, 12:40 AM
  3. general info for wood cnc
    By jelson in forum CNC Machining Centers
    Last Post: 01-11-2009, 03:47 PM
  4. Good general info site
    By vger in forum CNC Machine Related Electronics
    Last Post: 05-08-2007, 04:50 PM
  5. Looking for general info
    By juntunen in forum MetalWork Discussion
    Last Post: 02-22-2006, 05:16 PM
