586,060 active members*
4,158 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > My Sound Dampening Enclosure for almost finished CNC Router
Results 1 to 8 of 8
    Oct 2012
    17
    Hello All,
    I thought I'd share my progress with my sound dampening enclosure I've been building for my CNC router.
    When I started building my CNC, I knew I'd have to have some sort of enclosure, and with the neighbours that I have it would have to be pretty effective at cutting down the noise.
    Enclosure is made of an MDF outer shell, then a 10mm gap, then the inside "panels", which are HEAVY.
    Each panel is made up of the following layers. 12.5mm plasterboard, CLS timber frame filled with 50mm Rockwool sound insulation, 10mm carpet, 18mm MDF, 10mm carpet again (around the rim only this time, leaving a 10mm gap in the middle).
    The completed panels are extremely heavy. After calculating based on the weight of a sheet of mdf and plasterboard, I'd have to say close to 45-50kg each. Thickness of each panel comes to around 110mm.
    The only screws used on the panels was to make the CLS frame. All layers are glued together using either contact adhesive (for the carpet, mdf layers) or gripfill (for the plasterboard layers). I wanted to minimize the amount of vibration transference through screws and bolts by omitting them altogether.
    Here are a few pics. I still have the front panel/Door to make tomorrow, and I'm still unsure how I will hinge it. Also to do are ports for cables and baffles for fans/airflow.
    May 2008
    1185
    Re: My Sound Dampening Enclosure for almost finished CNC Router
    Looks nice.
    The MDF will block most of the sound. I have found that carpet is good only for a small range of frequencies. It is cheep.
    I would bet it will knock off enough sound to be OK.
    You need to add vents to cool the router.
    youtube videos of the G0704 under the name arizonavideo99
    Oct 2012
    17
    First sound test complete. Using a laminate router at max rpm. You can hear how the sound level drops quite a bit once the third latch is hooked in and pulled tight.
    https://youtu.be/xpBMiklj3gA
    Oct 2012
    17
    Sound Test 2
    I've added the outside polycarb window now.
    https://youtu.be/VTtwhtDYiG8
    Jun 2011
    692
    Nice, that's quite a significant improvement!
    Jun 2019
    Hello! Excellent result! Also soundproofed your machine, very pleased with the result. You can talk in a whisper) I apologize that the whole text is in Russian, but everything is clear there)
    https://www.youtube.com/watch?v=Apc6Lctxn0A
    https://www.youtube.com/watch?v=6TaWe9pvSlM
    Feb 2005
    829
    webmax, amazing!!! that enclosure really really works!
    Oct 2012
    17
    Quote Originally Posted by webmax View Post
    That is awesome webmax. Very well built and the sound deadening works really well. Congrats.
  1. Tormach enclosure and sound reduction
    By Dallas J in forum Tormach Personal CNC Mill
    Last Post: 05-19-2016, 05:37 PM
  2. sound dampening enclosure
    By thedudeabidez88 in forum Benchtop Machines
    Last Post: 11-17-2015, 09:54 PM
  3. Finished my 770 enclosure
    By RussMachine in forum Tormach Personal CNC Mill
    Last Post: 02-02-2014, 07:10 PM
  4. Sound and dust enclosure
    By nickacarroll in forum DIY CNC Router Table Machines
    Last Post: 01-09-2009, 03:21 PM
  5. Finished Enclosure! Taig CNC-Pictures!
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 07-09-2008, 06:15 AM
