586,071 active members*
4,057 visitors online*
    Jan 2010
    76
    Backlash comp in CV mode
    In Mach3 I was told not to use backlash comp when in CV mode. Does the same limitation apply with UCCNC? Just switched over yesterday.
    Dec 2014
    62
    Re: Backlash comp in CV mode
    i use it in uccnc and it seams to work fine. no stopping in an arc as with mach3.
    michael
    Jun 2015
    943
    Quote Originally Posted by basskitcase View Post
    I'm using it on the plasma and it works fine with the UCCNC. My machine has a small backlash about 0.2mm on the racks and pinions drive on the X and Y and the compensation is unnoticable, no stopping like how it happens with mach3.
    I'm running the plasma machine always in G64 CV mode.
    Jan 2010
    76
    Thanks all, I will turn it on and give it a shot.
  1. OSP5020L Backlash Comp
    By powaserdavid in forum Okuma
    Last Post: 09-24-2012, 08:42 PM
  2. SmoothStepper Backlash Comp
    By michaelthomas in forum SmoothStepper Motion Control
    Last Post: 10-25-2011, 12:39 AM
  3. Does anyone use backlash comp in Mach??
    By bluumax in forum Mach Mill
    Last Post: 04-29-2008, 10:54 PM
  4. backlash comp or not
    By woffler in forum Mach Mill
    Last Post: 04-19-2008, 08:54 AM
  5. Problems with backlash comp
    By Green0 in forum Machines running Mach Software
    Last Post: 07-16-2007, 03:17 AM
