586,604 active members*
3,508 visitors online*
Results 1 to 8 of 8
    May 2018
    21
    Mach 3 stops executing code in middle of run
    Not sure what is happening here, but I am running a simple inlay code from Vcarve Pro. Part way through the run, the CNC shuts down. Same place every time. CNC Router Parts Pro4848. Does not appear to be an error code anywhere in Mach 3 that I can find. The "Flood" light is flashing? Not sure why as I don't have a liquid-cooled spindle.
    So, is this a Mach 3 issue or something in the VCarve?
    Insight on where to look would be appreciated!
    Stan
    Re: Mach 3 stops executing code in middle of run
    Does it stop at or near line 500?
    If so, it's because Mach3 is in demo mode.
    May 2018
    21
    Not sure, I will check. What does that mean? Used it yesterday without incident, so not sure what changed??
    That would mean the license is not working.
    Does it say Licensed to (your name) in the Title bar?
    May 2018
    21
    Yes, still shows as licensed to me.
    Were there any messages when it stopped?
    Are you using a parallel port, or a motion controller? If a controller, which one?
    May 2018
    21
    Just tried a totally separate file generated in Vcarve Pro and it executed fine, so I assume it must be something in the original code?
    No obvious error messages. Gantry just stops and the spindle spools down, same place every time.
    I'm going to re-generate the G-code from Vcarve and try it again.
    Thanks for your ideas on things to check!
    There should be a message on the screen.
    Is the reset button flashing when it stops?
  1. K2CNC/MACH3 stops in middle of job
    By lumenire in forum K2CNC
    Last Post: 11-11-2018, 03:23 PM
  2. CNC stops in middle of code.
    By scottgeorgeson in forum Australia, New Zealand Club House
    Last Post: 02-29-2016, 01:32 AM
  3. Heiz High-Z S-1000/T - stops in middle of job
    By trusley_mike in forum Commercial CNC Wood Routers
    Last Post: 08-15-2014, 04:49 PM
  4. Cnc stops in the middle of Gcode?
    By Peeps in forum Machines running Mach Software
    Last Post: 02-03-2012, 12:42 PM
  5. VF-2 stops in the middle of a program!!
    By southernexplore in forum Haas Mills
    Last Post: 08-12-2009, 06:34 PM
