586,377 active members*
2,610 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > error "3 too many digits" ? Conquest T42
Results 1 to 9 of 9
    Feb 2019
    38
    I'm making progress, computer talking to the machine, first pass at the post processor is done.
    I'm getting an error "3 too many digits". I think this has something to do with the a feedrate. I've seen other people have had the same error with mill controllers and fixed it by changing 1404.2 parameter on the controller. I have an 18T controller and this parameter doesn't exist. Any ideas?
    G01 X0.0506 F0.003
    Dec 2013
    5717
    Re: error "3 too many digits" ? Conquest T42
    Is the G code set to G95 (feed / rev) or G94 (feed/min) ? For that feed rate it should be G95
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    38
    Ignore my previous comment about the problem. I'm clearly out of my wheelhouse guessing at what the actual problem is. Can you scan through the code and see if anything sticks out as having too many digits?
    Dec 2013
    5717
    Try this
    N1(FACE1)
    M470
    G28 U0.
    G30 W0.
    G54
    G98 G18 M24 (changed G99 to G98)
    G50 S2500
    T0101
    (NPR51)
    M08
    G97 S633 M03
    G00 Z0.1969
    X4.825
    G96 S800 M03
    Z-0.035
    X4.025
    G01 X3.785 F0.008
    X3.625
    X-0.0312
    X0.0819 Z0.0216
    G00 X4.025
    Z-0.105
    G01 X3.785
    X3.625
    X-0.0312
    X0.0819 Z-0.0484
    G00 X4.025
    Z-0.175
    G01 X3.785
    X3.625
    X-0.0312
    X0.0819 Z-0.1184
    G00 X4.825
    Z0.1969
    G97 S633 M03
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2013
    5717
    G99 and G98 seems to be used for IPM vs IPR, I am getting conflicting information. One source says G95, G96, but my book says G99, G98, so going with the book.
    I corrected the post above.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    38
    Try this
    N1(FACE1)
    M470
    G28 U0.
    G30 W0.
    G54
    G50 S2500
    T0101
    (NPR51)
    M08
    G97 S633 M03
    G00 Z0.1969
    X4.825
    G96 S800 M03
    Z-0.035
    X4.025
    G01 X3.785 F0.008
    X3.625
    X-0.0312
    X0.0819 Z0.0216
    G00 X4.025
    Z-0.105
    G01 X3.785
    X3.625
    X-0.0312
    X0.0819 Z-0.0484
    G00 X4.025
    Z-0.175
    G01 X3.785
    X3.625
    X-0.0312
    X0.0819 Z-0.1184
    G00 X4.825
    Z0.1969
    G97 S633 M03
    Thanks!!!!
    That didn't work. Is there a way for me to determine which line of code causes the problem from the controller?
    Dec 2013
    5717
    Not that know of.
    One more thing to try is to look at parameter 910, bit 4, if it exists in your system. That parameter is Feed Digits, or something like that. I think the options are 0 and 1
    Like I said in another thread, there is a reason I ripped everything out of my lathe that said Fanuc on it.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    38
    I'm starting to agree with you. I will try that next.
    Now the memory is full on the controller. I tried to delete some of the old programs but I get an error. "WRONG FORMAT". These things are a little cranky.... aren't they????
    Dec 2013
    5717
    Yup, very cranky. As I recall we never did make any chips with the Fanuc controls, just a couple dry runs. I think we screwed around with the Fanuc controls for about 2 weeks before we had enough screwing around.
    Jim Dawson
    Sandy, Oregon, USA
  1. Replies: 3
    Last Post: 09-11-2020, 05:12 AM
  2. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  3. Fanuc Oi-MB "750" and "5136" error
    By emre2blue in forum Fanuc
    Last Post: 11-27-2017, 07:37 AM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. Mazak T-2 "20 NMI Emergency Stop" Error"
    By Jeff_Y in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2011, 05:35 PM
