586,060 active members*
3,343 visitors online*
    May 2018
    7
    NCStudio weird error message!
    Hi everyone
    I run NCStudio 5.5.6 on a 32-bit Windows XP PC. I recently started getting the following symbolic message which causes my machine to stop:
    ¼Ó¹¤³ÌÐòÔËÐдíÎ󣨵Ú19ÐУ© £ºÔ²»¡±à³ÌÓÐÎó¡£ÇëÐÞ¸ÄIJKÔ� �Á¿Ä£Ê½²ÎÊý
    I think it might be related to G02/G03 commands because my other codes with only G01 commands run perfectly.
    Is there any manual or website where I can look up the meaning of this message? Or can anyone tell me why my software or machine is losing it when I give it G02 and G03 commands? I'm pretty sure it could handle them in the past...
    Any help will be greatly appreciated!
    Cheers
    Makaplan
    Mar 2023
    Re: NCStudio weird error message!
    Hi Makaplan,
    just wondering how you resolved this issue?.
    I have just recently got a similar crazy message on my machine running NCStudio, and any new Gcode files I try to run, the machine will only move to the beginning of the vector it is about to cut, then stop with error code.
    Any help would be appreciated.
    Cheers
    Mark
  1. This error message indicates that either certain
    By goodcleaners in forum Mechanical Calculations/Engineering Design
    Last Post: 11-25-2017, 03:21 AM
  2. NCStudio - z axis limit error
    By zac123 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-23-2014, 03:39 AM
  3. "master encoder state error" AB ultra100 error message
    By ShapeShaver in forum Servo Motors / Drives
    Last Post: 07-31-2013, 04:09 PM
  4. Weird Mach3 error- slowing to a crawl at end
    By Datamancer in forum Mach Mill
    Last Post: 08-04-2012, 11:47 PM
