586,077 active members*
3,673 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Nakamura tapping cycle
Results 1 to 7 of 7
    Jan 2019
    4
    Hello everyone, how is everyone doing?
    I’ve just started working on a new machine our company just acquired. It’s a Nakamura NTJ-100 with Fanuc 31i. And I’m having issue with tapping cycle. And I don’t have any experiences about it. The spindle is limit to 55-56 Rpm when tapping even though it’s commanded S300 or whatever I’ve tried S1600 and it still tapping at 55RPM. Any helps is appreciated.
    Jan 2019
    74
    Is there an M-code to select a different gear?
    Jan 2019
    4
    No M code to select different gear
    G0 C0
    G0 z1. Y0 X0
    M29 s300
    G84. R-.9 z-.375 F.025 M86(locked c-axis)
    G80
    It will tap and gives good thread but just slow!
    Jan 2019
    74
    check out these parameters"
    3705 B3(sgt)
    3761
    3762
    5200 B1(vgr)
    5201 B2(tdr)
    5203 B3(rgs)
    5241
    5242
    5243
    5244
    Jan 2019
    4
    Thanks CadCamSam
    This is what I know
    5241 s1 1000
    S2 3200
    5242 s1 1000
    S2 1600
    5243 s1 1000
    S2 3200
    5244 s1 1000
    S2 3200
    We have three of these machines and the above 5241-5244 are the same. Other two work fine, for this particular machine the tool is mounted at a different orientation for this particular part, Axial vs radial.
    Will try playing with your suggested parameters tomorrow morning
    In the mean time I did Hand coded to tap the long way with no good result. Thread oversized occasionally. Spindle and feed are probably not synched
    Jan 2019
    74
    I see. I would wonder if you have a X axis encoder for rigid tapping. That may be an option, or not properly setup. Try doing the same on the other machines.
    Jan 2019
    4
    I tried them parameters you suggested, it didn’t improve the Rpm
    This morning we tried running the tapping code on the other machine (Machine F) and it worked as expected. Engineer thinks it parameters issue and wants to download parameters of the two machines and do a comparison. Thanks for all the input CadCamSam
