586,196 active members*
4,233 visitors online*
    Sep 2010
    54
    driver test pulse to fast
    Mach 3 I have installed on win7 32bit. Before 14 days the problem arose, With the axis began to lose the steps. I checked the mechanical circuit cnc, replaced the leading bushings. Mechanical damage does not appear. Because I did not fix the errors, I examined the wires. I changed all the wires from the FB25 to the controller and I changed some two-way terminals to the cord connector, but the error did not disappear. I tested the driver test. The test most often showed the pulse is too fast and sometimes the pulse is too slow. Could he blame the computer for dropping the steps?
    Attachment 415192
    Re: driver test pulse to fast
    Yes, that driver test is not suitable. The graph should show a flat, straight line, with little or no spikes, and you should have a steady pulse rate.
    Sep 2010
    54
    Would using the UC100 USB motion controller solve this problem?
    Yes.
    Sep 2010
    54
    Today I tested the UC100 USB motion controller connection.
    I made four tests, the error does not appear anymore, and the engines do not rush. He works fine for once.
  1. Pulse/test not firing
    By bratan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-05-2015, 02:31 AM
  2. Can you pulse a digital driver manually?
    By Fastest1 in forum Stepper Motors / Drives
    Last Post: 08-18-2011, 06:35 AM
  3. Driver test pulse variations. Are they to large?
    By jaru-eri in forum Mach Mill
    Last Post: 02-26-2008, 01:23 AM
  4. Driver test problem...
    By jaru-eri in forum Mach Software (ArtSoft software)
    Last Post: 02-20-2008, 12:38 AM
  5. Running with a wave driver , too fast?
    By Konstantin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-30-2004, 11:11 PM
