586,105 active members*
3,324 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Alpha cam tool definition
Results 1 to 2 of 2
    Question Alpha cam tool definition
    Hello. I'm using Alphacam Ultimate Router 2017 R1
    I want help with tool defining, in alphacam.
    Imported the tool foto.
    I did the tool drawing, defined it as USER-DEFINED. And it works only on simple commands like, pocketing, drilling, finish milling ect. I can't use this tool with commands, 3D (surface,solid machining) getting error (tool must be ball end). If i'm using advanced surface, wire frame,multi axis or swarf machining command, alphacam just crashes.
    So question, what i did wrong? How to define specific tool for 5Axis machining? Adding couple pics, and ard file with tool drawing and task which i what to complete.
    Thanks,
    Silvestras
    Mar 2019
    4
    Re: Alpha cam tool definition
    yes you right about this problem i usually take ball end tool and i make operation on it and after that i change id and offset cut feed spindle feed and save it i hope these help you
  1. G-simple tool definition - pocket says tool is too big
    By muttstang in forum Uncategorised CAM Discussion
    Last Post: 10-09-2014, 03:55 PM
  2. Tool definition in RhinoCAM
    By FoxCNC1 in forum Rhinocam
    Last Post: 04-06-2014, 12:18 AM
  3. Tool Definition & Verify
    By Andre' B in forum Mastercam
    Last Post: 03-14-2012, 06:16 PM
  4. Tool definition
    By Ywes55 in forum HEIDENHAIN -> iTNC530 PC-SOFTWARE
    Last Post: 02-11-2010, 04:43 PM
  5. Tool definition
    By David Da Costa in forum Mini Lathe
    Last Post: 07-04-2006, 04:48 PM
