586,512 active members*
3,575 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > please, how to check alignment for small tool ...
Results 1 to 20 of 25
Threaded View
    Jun 2015
    4154
    hello i have a small id turning knife ( image 00 ), that is mounted like in image 01
    each time i change that tool, i have to take out the sleeve from the machine, because there is not enough room inside the cabinet, so the keys won't fit ...
    when i put it back, is a gamble, and there is a big chance to have the tool misaligned, in X and/or Y
    i also can't check it's alignment, and, as a result, a new tool may break after machining 1 or 2 parts, especialy because the tool is small, so is very sensitive if not aligned properly
    problem is that there is too much overhang, and i can't achieve repetability when changing that tool, and also i can't check it's alignment ... pls, how to deal with this situation? i mean, is there a 'normal' approach ? kindly
  1. how to check axis alignment on NL4300
    By mattk1987pick in forum Mori Seiki lathes
    Last Post: 08-22-2016, 06:51 PM
  2. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  3. VF2 Tool Alignment - HELP!
    By Dennis Fletcher in forum Haas Mills
    Last Post: 03-15-2010, 07:10 AM
  4. Quick check of 5 axis alignment
    By Sissie in forum Want To Buy...Need help!
    Last Post: 10-13-2009, 01:54 PM
  5. tool carousel alignment
    By rubino2112 in forum DNC Problems and Solutions
    Last Post: 12-27-2006, 07:26 PM
