586,069 active members*
3,733 visitors online*
Thread: error
    Feb 2014
    33
    error
    can someone assist me with this error
    Attachment 415346
    thanks Karl
    Mar 2011
    463
    Means the axis was out of position, either moved further than expected (i.e. runaway axis) or didn't move as far as expected (i.e. motor power cable is disconnected).
    These are the two extremes, yours is likely somewhere in the middle but without detailed information, can't be specific. There are many potential causes for either.
    Dec 2006
    584
    Re: error
    With the machine off you need to remove the left hand X axis way cover and look at the motor electrical connections and turn the ballscrew to make sure it turns easy
    It help if you gave us more info on the problem along with the type of machine and drives. Do you have scales??
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Feb 2014
    33
    Re: error
    thanks for the help
    one of the bearings went bad and í change it, and all is good now
    Karl
  1. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  2. Fixed BMDC Error, now have overactive feed error. Help needed.
    By victorgallas in forum Bridgeport / Romi Lathes
    Last Post: 11-01-2014, 11:22 PM
  3. Replies: 0
    Last Post: 07-17-2014, 04:12 PM
  4. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
  5. Yaskawa Servopack error: A.D1. Motor Load Position Excess Error
    By Syphonics in forum Servo Motors / Drives
    Last Post: 04-26-2012, 07:53 AM
