Re: Help needed - VFD in NYC
Mine is set up and working on Mach3, air cooled and same drive. But I have the pre-wired CNCRP panel and it needed to put out 0-10 vdc for it to work on that. But I also found out the PWM signal out was not right for this drive. Do you have it running on-off from Mach3 and adjusting the speed from the VFD keypad arrows?
I really doubt if your going to find someone willing to drive into NYC to set up your VFD .
